My first go at drag racing pretty clean run. 60ft could be better but its a track setup and very very stiff :P
R32 GTR
ET: 11.495
MPH: 121.57
FUEL: ULTIMATE
TYRES: 255/40/17 A048'S
NITRO: NO
video link - right click save as
Edited by Angus Smart
My first go at drag racing pretty clean run. 60ft could be better but its a track setup and very very stiff :closedeyes:
R32 GTR
ET: 11.495
MPH: 121.57
FUEL: ULTIMATE
NITRO: NO
woah!! for a first run, thats awesome!!!!
R31 silhoutte
60ft:1.68
10.21 at 140.89mph
pump fuel, full exhaust, 25psi, footbrake(transbrake not working), et street bias plys
Rb30 SOHC, 850hp gt4294, powerglide, 3500rpm stall, 3.45 diff gears.
a chick in the 10s!!! AWESOME!! :) nice work :D
Thankyou! i think i might get the fcon tuned, my afr's lifted somewhere from below 9 to somewhere a bit leaner
get a tripod and an in car camera and do it again in a few weeks. it should be another fun night for the few minutes of running! and hours of waiting :(
Geez blue brother, I wouldnt mind going next time your out! What brand tyres? :thumbsup:
Geez blue brother, I wouldnt mind going next time your out! What brand tyres? :)
Hey just using yokohama a048's i'll probably head out in a few weeks! you had much luck selling yours yet?
howd you get down to 10.7? i was aiming for something like that :)
howd you get down to 10.7? i was aiming for something like that :rofl:
Just drive the ass off it Blue Brother!!! Federal tyres at 20psi. Plus it was only 10.9 :w00t: . Plenty of wheelspin though. No real luck selling it yet but thats fine cos I love her! :blink:
Car: R33 GTST
Turbo: Slide high-flow
Tyres: Federal SS595 255/45/17 @ 18psi
Date: 03-05-07
Time: 11:05pm
Output in rwkw: 215 according to the Allstar dyno......
Track: Willowbank
Air Temp: 16 degrees
Track Temp: 25 degrees
Humidity: 1015mB
Reaction time: .597
60ft: 1.841
330ft: 5.36
660ft: 8.22
1000ft: 10.68
ET: 12.70
MPH: 112.3
Car: R32 GTST
Turbo: 2535
Tyres: M/T 255
Date: 02-05-07
Time: 09:58pm
Output in rwkw: 235
Track: WSID
Reaction time: .446
60ft: 1.868
330ft: 5.274
660ft: 8.122
ET: 12.55
MPH: 107.8
First time @ any leagal drags.. loved it !
Edited by jnr32r
Car: R33 GTST
Date: 16-05-07
Time: 5:39pm
Track: Willowbank
Air Temp: 21 degrees
Track Temp: 29 degrees
Humidity: 1018mB
Reaction time: .782
60ft: 1.73
ET: 12.58
MPH: 111.3
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
