hi ive been thinking of doing a rb26dett conversion for some time now on my r31 series 3 wagon (yes a r31)...
ive found some decent stuff for sale on here to do the conversion... my main worry with buying a halfcut is the state of the engine... ive had the motor compression tested and got 140-150 all round... is this too low for a gtr... ive been reading lately in hpi that a ideal compression is 160psi... is this 140-150 compression too low... should i keep looking... how much range should i allow in the compression (ie say 143 lowest 152 highest for example) is there a percentage that the compression figures should range in???
also on the gtr note... can i use the gtr box to run in rwd and block off the front of the transfer case??? what to do :(
thanks for your help
Rick
https://www.sau.com.au/forums/topic/91931-rb26-compression/
140ish is fine.
iv seen them range from 110-140(not on the same engine.
its also important on the type of tester used. the ones with the long hose give a low reading, the one to use is the push-on type.
you should get the bores inspected with a borescope too.
generaly 10% variation is acceptable. :D
https://www.sau.com.au/forums/topic/91931-rb26-compression/#findComment-1658266
if the engine is cold as stated above, everything hasn't expanded and isn't offering maximum sealing, so those readings would be fine.
also one of the main things you should look for is even readings across all 6 pots, if one or two pots are out by a significant margin, then its fair to say that something may be a miss inside the engine.
if they are all fairly even across the board then its fair to say its an honest motor.
https://www.sau.com.au/forums/topic/91931-rb26-compression/#findComment-1658487
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
