Time to ditch RAC, which insurer (I'm not a pimpley faced kid)
  • Replies 50
I dont understand why more people dont just buy a clanga or drive a NA car till they are a little older and can afford insurance on a turbo... makes more sense, be patient, save some money and get the car you want a little later and save money on insurance.
  • 3 weeks later...
