if i use these struts in the hr30 do i have the use the r31 insert or will the r30 insert fit?
i'm getting a set for my r31 gxe, but wanted to put them in my hr30 for compliance cause i have to take out the coilovers, i can still use the r32 calipars and rotors on the import r31 struts...
Edited by rsx84
https://www.sau.com.au/forums/topic/91960-hr31-struts-in-a-hr30/
From memory, the R31 struts are shorter than the R30 inserts. You will need to use the R31 strut and insert complete (and if you are doing it for compliance / rego purposes only, why would you care).
Oh, and when you find a second set, just shoot me a PM please... :D
Cheers,
Matt
The Australian built R31 struts are different to Japanese built ones. The inserts are different between both.
Most import sedans and coupes have the same struts and inserts, though I have heard that some of the R31 imports (RB20E/RB20ET models) have a strut more like the Australian models that have a non floating hub, which severly limits your brake upgrade options.
So I guess go with a set from anything RB20DE/RB20DET powered and you'll be right
i've got the konis book here and they class the sedan and coupe as the same insert??
Yeah,they are different though! Spacers under Aussie inserts is rather dodgey too,as the top of the Jap inserts are different shape to Aussie ones as well! And the import struts have a solid top hat with a proper ball bearing race,as opposed to sloppy rubber ones for the local model.
ok the question is. you say they are 1" shorter in shock length, would this also mean the total lenth of the strut is shorter?, can the R31 fronts be bolted in onto a hr30 ?
If im thinking right, that would lower it 1"
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
