hey guys as the title states i am having a few issues with my 33
i just changed the plugs and a new air flow meter and coilpacks, but it still wont idol when its in low and mid rev range, it drives fine for 10mins put when u put the foot down it runs well but when u slow down and stop it just wont idol.
the things i am doing are
cleaning the injectors
fixing leaking dump pipe
adding a catch can and removing all the vacume lines
the engine its self is in gr8 condition, i can smell a bit of fuel in the car does this mean injectors? also the car wont idol and start when i stop?
what do u guys think it is a leaking dump leaking bov, injectors or an electrical problem?????
thanx 4 your help
andy
Edited by SLYAS 33
https://www.sau.com.au/forums/topic/91962-33-issues-please-help/
had the same sort of problem about a week ago and we put in new coil packs, new plugs, changed the afm and the ignitor pack. didnt help so we hooked up some diagnostic equipement and went for a cruise.
worked out a fw things and changed the timing and revs a little and it fixed it. just seemed to be out of timming and in need of a tune up.
might be the same for you
yeh i though timming but my mech said it was un likley but i will tell him again lol....
as for the lines and standard bov there still on there, taking them off tomorrow and gettin a new piece of pipe made up, it has been set up how it is now for the last year and been fine
thanx people
andy
Edited by SLYAS 33
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
