hey guys
i know that there is a thread with peoples wheel sizes, offsets etc.
but i want to know what other make+model car stock rims will fit onto a R32 GTST type M
ive tried stock rx7 rims and they cannot fit over my brake calipers (standard typeM
calipers)
i think s14 and s15 rims, r33 and r34 rims fit but not 100% sure and dont really want to spend much at all on stock rims
so my question is what really cheap stock rims will fit onto my r32 gtst (will clear my brakes)?
cheers
mitch
https://www.sau.com.au/forums/topic/91971-stockies/
Do you want rims for drift??
I've tried R32 GTR wheels on rear, they fit very well, and fill the guards great.
Also, Z32 rims (300zx). have to be one of my cheapo drift rim of choice. 16x7.5 They fit r32 fine.
If you are interested in buying rims for drift, I some pairs you may be interested (PM me if interested)
- pair z32 rims
- pair r32 gtr rims
- pair crappy 15's which only just clear the brakes (best to use 2mm spacer to be sure. can throw them in)
https://www.sau.com.au/forums/topic/91971-stockies/#findComment-1658484
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
