Graham West have been nothing but honest with me, I reckon they are very trustworthy - thats the main reason Im going there. They look you in the eye & tell it like it is.
Heres an example, was going to have highpressure fuel lines installed, they reckon after looking into it, that the current Jap spec stuff in the car is way better quailty that general aussie spec stuff. So they didnt do the job to save me money and make sure I wasnt going backwards with my car mods.
But Id suggest every mechanic has good / bad stories about them. I deal with Ashley & mainly Brett West, both are top blokes.
I still dont understand this high pressure fuel lines thing. :)
Fuel lines to me are metal lines with rubber lines/hose connecting up to the fuel pump, fuel filter and finally the fuel rail.
Its always worth changing fuel line hose after its 5 or more years old, especially if you plan on running close to the maximum rated pressure.
I'm unsure with the R33's but with the R32's Nissan use crimp type clamps on the fuel line hose. These hose clamps are total crap and would not trust them to hold the full 75psi pressure that EFI fuel line hose is rated at.
Check your fuel hose clamps and fuel line hose for *any* little cracks.
Head down to the local sprints, motor mates, supercrap, autobarn and ask for a few meters of EFI fuel line hose. It will be expensive per meter if not then chances are its std fuel line hose that is not rated for high pressure efi use.
To replace some of these little rubber hose pieces is a real pain in the arse, in the R32's you are required to remove the fuel rail and possibly the plenum, it takes ALOT of time. :)
Edited by Cubes
yeah i have heard the same from a few other people. but he has hot cars out the front all the time. probably fixing his own stuff ups. i had mine tuned at high-tech dyno on the corner of south & daws road, had no problems, speedy service and fixed price quotes. i recommend them, plus the place looks spotless and organized always a good sign!
anyone know a good place to pick up good turbos from (2nd hand). or anyone that reconditions them. silly question maybe but i am new to the scene. someone suggested replacing the creamic exhaust with a steel one so i can run more boost. ceramic wheels spool up quicker than steel ones right? port matching also gives better flow therefore more power? anyone with suggestions about a good turbo/tune shop, otherwise i will stick with hi-tech dyno. feedback?
Graham West are good, but very expensive. They squeezed 173RWKW out of my old CA18DET sil80 on a "safe" tune.
I have heard nothing but good things about boostworx, will be taking my new car there from now on.
Four Brothers - Stay as far away from that place as possible, far far away.
TURBO REBUILDS...
To ALL,
One of adelaides best turbo modifers/ rebuilders is Bill Keen of A.T.S. (adelaide turbo service) marion rd,marion.
Regards,
SKYLINE (kym)... B)
Edited by skyline
TURBO REBUILDS...
  To ALL,
  Regards,
            SKYLINE (kym)... B)
any relation to John Keen (formerly of Turbo Tune) ?
Morepower have done a lot of work on my car, and I've had no problems. I didnt mind Tillbrooks but the price was a lot higher.
What sort of prices are we talking for Morpower? Obviously depends what they are doing, but what have you had done there?
Cheers mate!
Look, at the end of the day everyone takes their cars to a place that they trust.
1 thing that cannot be guaranteed is the workmanship of anyone on your car. The only way you are going to get good service is by customer loyalty. Find someone who knows what they are doing, and stay with them.
Me- I know Shaun @ Boostworx does know his stuff, and does a good job. I go back when i need to.Why? Because i know he wont fix bogus problems, doesnt fark around, and he doesnt charge like a wounded bull.
Asking people what problems they have had is fine, but dont take someones opinion of a workshop the final say. Just because they have great service, doesnt mean you will get the same.
ps - ive lost a motor due to someone overtightening a tensioner bearing. I wouldnt take my Turbo to be Tuned there :(
I met Shaun through Tim and Ivan @ RPM.
Tim used to do all my work, Tim sold up Ivan took over with Shaun managing. Shaun's been around the scene for many years, he knows what he's doing and best of all..... He doesn't pop motors due to stating... 'ahh I'll pull another 20rwkw out of it', exactly how Tim used to work.
Tuning isn't rocket science, some simply try to push it too hard, running too close to the edge.
Edited by Cubes
I agree with Cubes, My car will be re tuned thru Shaun soon as well as anything else i need. The only other place i would recomend is Graham West, they have level heads on them, and always talk about SAFE tunes NOT MAX, but with a higher price tag than Boostworx....you do the math!
Also know of a old mates RX7 that blew up on the OLD RPM dyno back in the day, almost seems fitting that he(tim) is now at Tilbrooks......COUGH COUGH
Damn dude that was quite some time ago, all i know is they were doing work on it, then chucked it on the dyno and BANG!!!
Look i'm sure there was more to it but hey when a car is on the dyno you can see if things are wrong and shut it down, Like shaun had to on the SAU dyno day for me, was running well lean. Giddyup!!
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
    • Bit of a similar question, apprently with epoxy primer you can just sand the panel to 240 grit then apply it and put body filler on top. So does that basically mean you almost never have to go to bare metal for simple dents?
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
