went down to kamome on saturday.wasnt too bad.reasonable gallery and a few cars drifting.
streeter,what did they get you for on your shaken?ive got an e-manage and exhaust.going to put a fmic and a bigger turbo down the line.will they get me for that?
well it started off being too low, no cat, too loud, wheels too far out. no emmissions, aero too large for s13 shakken specs, no rear seat, needed padding on the roll cage, tie rods, rear upper arms, air pod, and other stuff I cant remember...
the real sh!t hit the fan when the car was still registered as a non turbo Qs but had a turbo engine. So basically its in the middle of being de-registered and re-registered as a "modified" s13 Qs with sr20det. Other issues that have made the process longer is that the registered owner is the guy I bought it off back in Kochi so there has been a paper work nightmares and also the the garage sorting the shakken (West aka Bai) has gone to America for drift demos till November 10th.
Anyway with any luck and probably more money than Id like to imagine it will be on the road again in a week or so.
They dont seem to mind turbo upgrades or intercoolers if you keep the polution gear etc... but you dont worry about that kinda junk till your shakken is due.
