How many Buckets?
33 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
what the hell? 8-10... crazy...
i just use like 2 buckets... spray the car down at carwash, fill up bucket with water and add cleanser... wipe down car with sponge (using that cleanser water)... spray with water again... chamois it... add polish/wax...?
Edited by Menthu_Rae
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1658895
In light of the "How often do you clean your car" thread, I thought it would be interesting to see how many buckets the average budding car enthusist uses to clean their pride and joy?
Too many...
I'm sure I would use a heap less water if I used the hose.
On a serious note, I probably use around 6-8 buckets of water (big 20L bucket as well) when I wash the car. I've kinda given up using the bucket though, so I usually end up getting the car washed at a cash wash while I enjoy my caffine hit on a Saturday morning - which I plan on doing shortly :P
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1659076
i use 0 buckets of water!
cause i use Dri-Wash 'n' Guard
its the BEST you people should try it
its a waterless carwash
just buff on and polish off
and i am yet to find a better one (it removes small scratches and everything)
only time i use water is if car is REAL dirty (which is never!! of course)
i only used water the first time cause if u use dri-wash, then water, then dri-wash again it locks in the wet look and is awesome
Should try it nothing better
RellikZephyr
Edited by RellikZephyr
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1659096
How many buckets would you fill with the water you used to hose the car down twice?
Now how many buckets would you need if you had to fill up buckets of water first, and then throw the buckets of water over the car to wet it, and then rinse it?
I have one of those hose "guns" that I "shoot" when I need water.
It takes about 30 seconds to fill up my bucket with water. It takes about 45 seconds of spraying to intially rinse down the car, and then perhaps a minute to rinse off the suds after washing. Say about 2 minutes of hose use all up. So that's about 4 buckets?
I can tell you WITHOUT A DOUBT that it would take me about 6-8 buckets of water just to do the final rinsing off after washing to get the suds off the car. Pouring a bucket of water to wash things is sooooo inefficient.
So I think it's quite reasonable to suggest:
I would take 12-14 buckets of water to wash my car with a bucket, and only 4 buckets worth with a hose.
Congratulations NSW Government on another well thought out water restriction! :)
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1660074
what a waste of effort, i dont know anyone who actually uses buckets to wash their cars, just trigger hoses, same shit, o and make sure you wash the concrete driveway down to when your washing your car, so you dont have to waaste your time with the broome..
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1660078
Congratulations NSW Government on another well thought out water restriction!  :rolleyes:
Gotta agree with that. I use the hose most of the time as I'm sure I use much less water than if I fked around filling buckets and tipping them on my car.
However, I usually use the car wash to avoid the scrutiny of my neighbours, even though I'm sure this wastes more water than me with hose or buckets.
Edited by shyster
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1660227
Congratulations NSW Government on another well thought out water restriction!  :D
My answer exactly. Ive had neighbours complain and i just ask them to watch the difference between using a bucket and a trigger hose.
Everytime they see my side. The NSW gov has just inforced the bucket rule because people can not be bothered to use one so wash their car less which uses less water.
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1666745
the real question should be how many buckets does it take to drench the people who rat me out to the water restriction nazis...
answer, 1 per person.
I hear that. and they are usually the ones that are hosing down their driveways anyway when they not supose too ... divkheads <_<
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1672608
well i now have 2 rainwater tanks in my house. one is 5000 litres one is 3000 litres..hmm maybe it's 000s can't remember. either way i now have shit loads of clean free water to do with as i please. we have connected spray irigation to both front and back gardens and retracting lawn sprayers too. each tanks has it's own high pressure pump so you can hook up a hose and enjoy even better pressure than what you get from the mains. plus the irigtation system is computer controlled and has moisture sensors in the ground. it certainly is a kick arse system and means we can do what we want with the water. so if you drive past my house and see our irigation running don't whinge to sydney water as it's our water to do with as we please :)
https://www.sau.com.au/forums/topic/91990-how-many-buckets/#findComment-1673623
    • Update time!  The JZX110 had some maintenance needing to be done, so a lot of the seals with replaced to fix some oil leaks. Also used this opportunity to whack on a front mount that I'd bought some time ago.  I also finally got the rear lip painted and fitted.  I then got the exhaust done. It's just a catback for now. Custom made 3" stainless with a turn down. I could have a tip coming out, but it will require cutting the rear lip and possibly the bumper itself. So far I do like and it's made the car a little more zippy.  Close out with some nice pictures of the cars and a sneak peek of what's next.
    • Once you learn it all, you find you do the job once. But this is the best way to learn, as you won't forget the lessons
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
