Has anyone done the re-wire on a Ceffy?
I've followed the first post and tried a few other variations with no luck... All I can do is get the fuel pump to run constantly off the battery not accessory/ignition (ie pump running whilst the car is off)???
I didnt go quite to the extreme as the OP.
Mine just stopped working one day. No idea why. Pump relay and pump were both getting voltage, but nothing was working.
All i did was disconnect the stock 12v feed to te relay, then take the 12v feed from the 4ws Motor and connected that up instead seeing as the 4ws isnt used. . Tadaaa. Perfect running now. Uses the stock relay and earths. One wire to change.
  • 4 months later...
hey guys, im doing this mod atm, and ive been wondering wether this would work or not.
im running a dual stage boost controller off a switch in my dash. im wondering if i run the battery 12v feed to my relay, and then run a positive feed from my dual stage switch to make the relay switch on and off, and then tap the battery 12v feed from the relay into the std pump positive feed would this cause any issues?
doing it that way, i can still run the reduced voltage when im just cruising around the streets on low boost, and if i want to give it a boot full and switch over to high boost(low boost is only 10 psi so the pump will suffice without the extra volts) it will pump the extra voltage from the direct feed into my fuel pump to get the max out of it. this in theory should work, but what im worried about is the extra voltage running back up the line on the stock wiring to the stock relay and causing a problem. it would have been good to beable to shut off the stock pump wiring altogether, but the issue there is when the lines switch there will be a momontary lapse in power to the pump.
is it worth a try or should i just run it at max all the time?
Edited by OMY31T
  • 1 month later...
i guess u could try that if u really wanted to but whatever fuel the engine does not consume gets fed back into the tank anyways... id rather have more fuel then not enough when i "need" it...
  • 2 months later...
Did this mod yesturday, Have some photos and a diagram if anyones confused to show how I did mine, seems to have improved the car a bit
Relay mounted:
Wires spliced into pump wiring:
So you don't need to take the pump back out and replace that wiring also? I really don't want to do that if i don't need to
It would be better to re-do all the wiring, but I didnt want to pull the pump out and play around with the plug in the fuel tank cap etc so I just did it like this
The pump sounds louder so must be getting some extra voltage, no problems so far
Cheers mate will do your way and if i have issues rewire as necessary. Not pushing the pump that hard (similar power to what you have
hi newbie here from UK
r32 gtr owner.
could someone tell me what do you do with the old fuel pump plug??
i realise i can either cut for 12v before the plug, or fit a male spade fitting inside the plug on the 12v side to trigger the relay.
what do you do with the plugs negative feed?? simply cover it up with tape?? or does this still need to go to ground also?? (so in total, 3 wires to ground, plug/relay/pump)
thanks
ps, anyone confirm the wire colours for the + and - on the plug on a r32 gtr
  • 4 weeks later...
  • 3 months later...
Did you use the negative (gray) from the wiring loom as well or just the 12v blue?
Cheers
  • 3 weeks later...
Also my battery in the boot on the drivers side so all my new fuel pump cables are short in length, I'm running a walbro e85 400lph pump
What would be the best size cable to support this pump? 8gauge would be hugely overkill for such short distances?
i used 8g as i had few meters of spare cable, also make sure +ve and -ve are the same gauge, my one just plugs into the existing pin, wires inside the tank hasn't been touched
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
