I have an R33 and im sure my pump is doing the same thing - but then i was told that the voltage will increase as the engine loads up so there is no need in wiring the pump direct to 13v
whats the advantages of doing this ? ive go a walbro 255L ph
Whoever told you that only gave you half the story, as usual. R33's run lower voltage at idle, so the fuel pump doesn't keeping pumping excessive fuel around and heating it up needlessly in the engine bay. They revert to normal voltage above idle, that's the problem, the standard wiring limits the "normal" voltage.
The Walbro 255 lph pump only pumps 255 lph at 13.8 volts, at 12 volts it pumps ~210 lph and at 11 volts ~190 lph. The usual voltage at the pump we see is 11.2 volts when the standard wiring is used. That's at full rpm, max charge from the alternator and nothing else other than the engine running (eg; no aircon, no stereo). Plenty of other report the same, do a search for more details.
So if you are still using the standard fuel pump wiring you paid for a 255 lph pump and your are only getting ~190 lph out of it.
:O cheers :D
  • 4 weeks later...
Sydneykid - Is this direct wire worthwhile doing to a standard pump in an R33? Or could it burn it out quicker.
I have an R33gtst that I'm waiting to get tuned with a few mods..hoping for about 190rwkw. If I do the mod after the tune could it stuff the tune?
I wouldn't need any extra devices like what you were talking about would I?
Edited by benl1981
bwilkeson,
You previously mentioned...
high pressure fuel lines
You mean high flow fuel lines as in larger diameter?
How much is he charging for the wiring? Out of curiosity :)
Quickly ring him and ask to fit up a switch to disable the fuel pump(s) should you need to work on the the fuel system. Also aids as a kill switch should you be required to leave the car in a shady area.
I went a little silly on the fuses etc I used.. The 'mod' ended up costing me close to $60.
Edited by Cubes
What about in the case of an accident? Usually if you switch iginition off fuel pump will stop. Should you have to wire in so it is ignition switched? Did you do that Cubes? I guess you would have had to otherwise pump would be on all the time..Ill read the post agin later to see if it outlines this...
Cubes, getting Ashley to wire the direct feed coming thru the engine bay fuse box, there will be a fuse installed there that I can simply take out, if I so wish, to disable the fuel pump.
High pressure fuel lines will be used due to the extra boost (say 15psi) that will be run with the hiflow turbo next year, and also for the 10psi extra pressure that is possible with the Nismo F.P.R. Thats and extra 25psi being used over what they were designed for. Its a recommendation from SK, so I thought I should take him up on his advice.
Ben,
Which is why you wire it via a relay. Check out the first page part listing. :)
bwilkeson,
I've replaced all my fuel hose, pirtek have some good solid hose clamps to suit, much better than the cheap ones you get from the usual auto store. Fuel hose was damn expensive cost me $13 a metre for the good stuff.
Thanks for the advice, Cubes, with the 'switch', thats a good idea.
Im thinking its just high pressure fuel lines & stuff, not larger diameter for increased flow.
Only after around 200awkw with the hiflow turbo next year, expecting around 160awkw with this weeks mod efforts. For 200awkw I dont see the need for big diameter fuel lines, its not as if the Stagea is a 260RS (yet!!)
Brendan
Edited by bwilkeson
Can I wire it to the standard relay?  Im an R33 so battery is in the boot. Do you use the original wiring to trigger the relay
Thanks Cubes!  I'm not going to strain my old pump am I?
I bypassed the std relay. It could be done, its much simpler to simply run a direct feed from the battery in to the boot, run it through the fuse then in to the relay. Use the existing std pump volt feed as the trigger. Be sure to mount the relay up and down.
Since I mounted the relay vertical instead of sideways it hasn't jammed on. :O YET! :)
It won't strain the std pump, they are designed for that voltage.
Edited by Cubes
Nice one Cubes. Thanks a lot. So I guess I will buy a relay, does it really matter how you mount it? Run an earth line to pump aswell you think? Do you think connect it straight to that battery terminals?
Maybe I will do it before the tune so I don't risk getting there and it running out of fueling..
I ran an 8GA cable from the battery + to the fuse, to the relay, then 8ga from the relay to the external fuel pump and splice in the interal fuel pump.
I ran a nice 8GA earth from the fuel pump to the chassis for the earth. One again splicing the internal fuel pump into the earth.
Mount the relay vertical. It has appeared to stop mine from sticking on every blue moon when cold. I will replace it to be safe.
Edited by Cubes
If the relay fails the engine will stall.
Its the same if the std relay were to fail.
Either that or as some one previously mentioned the relay will fuse preventing the fuel pump from turning off when you turn the car off.
Edited by Cubes
I think the high/low is really unnecessary. It would be nice to have but it still didn't stop the fuel heating up and making horrible sounds with my external pump when I was running the stock ecu.
If anything, now with the pump receiving the voltage it should the pump is quieter.
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
