just trying to take off my intake pipe so i can get to the sparkies under the cam cover... and one of the bolts on the intake pipe wont come out so i cant remove the pipe!
screwdriver a million times, doesn't come out...
ratchet a million rotation, doesn't come out...
pliers, twist and pull up, doesn't come out...
the screw will turn, but it doesn't come out!!! it just turns and turns forever...
looking underneath the screw, the teeth of the shaft look perfect so i dont understand why its not coming out...
im getting pissed at this bloody screw, but im gonna stop before i lose the entire head of the screw...
any ideas how to get it out!?
https://www.sau.com.au/forums/topic/9200-stuck-screw/
Guest Boxhead
it could be a little rust that is stickin inside the the nut...
my grandfather(ex mechanic) tought me this, tap it with a hammer, not too hard but a half decent way.. maybe a couple of times, then use wd40 with the extender part to try and get it inside were it screws in.. let it sit . then try again
https://www.sau.com.au/forums/topic/9200-stuck-screw/#findComment-138036
coco69,
Sounds like the thread has stripped, have you tried using a flat blade screwdriver under the head (or the intake pipe) and twist to produce a upward pressure on the head (if you can get it under the head) at the same time as you try to undo it?
might work!
MEGA
https://www.sau.com.au/forums/topic/9200-stuck-screw/#findComment-138064
yeh, thanx for the replies guys...
tried both really...
tapped it lightly and greased it...
and also been wedging the screw upwards and pulling it up while twisting... doesn't budge... just keeps on turning and turning...
bought a screw extractor kit for like 9 bucks...
but gonna hafta drill thru the screw, so it'll wait till tomorow. :(
https://www.sau.com.au/forums/topic/9200-stuck-screw/#findComment-138097
coco69,
Screw extractors only work when the screw/bolt/stud head is broken off they weren't designed for what you wan't to do! as they are only a means to grip and turn the screw/bolt/stud anti clockwise which you don't seam to have any problem doing by the sounds of it! But you still might have to drill the old screw out and then tap a new thread!
MEGA
https://www.sau.com.au/forums/topic/9200-stuck-screw/#findComment-138148
mega, i thought screw extractors also cause the screw to climb up the extractor bit as its turned anticlockwise?
i get what you mean, i dont wanna open up the kit if its not gonna work, otherwise i can't return it and get my money back... hmmm...
bloody RB's with their gay intake pipes over the cam cover!!!!!!!
this is the only time in my life i actually wish i had gay 4cyl sr20... bloody intake pipe... >:(
https://www.sau.com.au/forums/topic/9200-stuck-screw/#findComment-138244
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
