Hey Yogi hows doing brother. Thanx for the reply and the feedback bud. Hows the front bar on your beast going?
BHDave, thats right it is still the stock AFM and you do make a valid point about the Z32 AFM. I was going to put one in my the boyz at Bel said it wasn't required at this stage as the air to fuel ratio was spot on after the tune but definatly something I will consider down the track. I am still going to consider the cam gears as I have been told it will help the turbo kick in sooner. And definatly will be running the car on a Dyno Dynamics dyno and am more than happy to get back to you guys with a power reading :P .
3lit3 mate I am happy for you champ sounds like you have a good car there. I wish you the best of luck with it champ and hey you never now we may cross paths one day and I would definatly be interested to see this car of urs.
Do you guys know if there is a sydney Skylines event coming up in the near future? It would be great to get together and meet you lads (if your based in SYndey that is).
Regards
Bruno
FST32R
Regards
Bruno
FST32R
Whats with the 'champ' thing?
I hope you haven't taken my posts the wrong way as it wasn't intended as a pissing match. I was merely commenting on the fact that you should easily achieve much higher results with the mods you have listed and I answered the few questions regarding my statements. I wasn't gloating or anything.
This may put it into perspective.
I have a friend with an R33 s2. These are his mods.
FMIC - 280X600X76
Sard Fuel pump
Garrett ball bearing turbo (very old and similar flow to a GT2530)
Power FC
His last Dyno was done on a Dyno Dynamics and achieved 238 rwkw on 15psi.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
