Gday all,
I have been having dramas with my clutch so me and my mate decided to replace the clutch fluid to try and fix the situation.
He got under the car, hooked up a clear hose to see any bubbles while I pumped the clutch pedal. Eventually all the old fluid came out and was replaced with the new fluid which we were replacing into the resvoir at the same time as we didnt wanna let it run dry.
When we thought we had it right, I pushed the clutch pedal in (it stayed in by itself) and he tightened the bleed nut. We pumped the pedal again and absolutely nothing happened. The pedal didnt push back under the hydraulic pressure and just stayed in.
We are now thinking we might have accidently let it bleed dry and have stuffed it. Any ideas???
Thanks in advance.
Never mind. Problem fixed. Bled from the nut next to the resevoir. Runs perfectly. ;)
Edited by vitruvian_man
https://www.sau.com.au/forums/topic/92044-bleed-clutch-problems/
dont stress.
its a pain.
youhave to do it in 3 stages.
1.open the bleader on the master cylinder and bleed that
2.open the bleeder niple in the big loop thing under the car.(square block that the clutch hose goes on to.)
and bleed it.
3.bleed the slave cylinder.
you should have a good pedal. but dont let the clutch pedel fly up on the up stroke.
yeah pain in the arse i did the same thing it takes a while to get peddle pressure as it takes longer to build as you have to push down crack, tighten, then pull up again will take you like 30 min if your lucky before it will feel good
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
