Hey guys im looking to purchase a stagea sometime soon, was looking at the 260RS, is there any differences between them and the autech version (brakes, suspension etc) or is it just the autech badge?
Thanks
Ok but do they have the brembo brakes or anything else GTR on them?
Or do they come with standard stagea brakes, suspension etc..
The ones i looked at didnt have the autech badge on them so i thought they may be different.
Does anyone have a 260rs that can tell me the differences, looked on heaps of sites but most of them only have the 2.5
Any problems with the import of the car?
Edited by (OO Black 33 OO)
Full GT-R running gear; engine, gearbox, rear cradle, Brembo's, 3-gauge cluster, and body tweaks by Autech.
There are a few '260RS lookalikes' out there that are non-Autech conversions. Note that all genuine 260RS' were WGNC34 RSfours that have been modified - they are body plated as being an Automatic RB25DET.
There are usually a couple for sale at about $25-$30KAUD
That's right. Further to this (and regardless of the fact that the build plate states that the car is an automatic RB25DET), Nissan's FAST software will be able to tell you if it is a genuine Autech 260RS when you put the VIN into it. If FAST doesn't confirm it, it's not the genuine item!
NOOB question, but do all stage's have attessa and HICAS or are they one in the same? just to help me clear some confusion i have, thanks scott.
Nope, Scott - only the AWD versions have ATTESA, and there are quite a few RWD Stageas here in Oz.
And only the factory manuals (RS-Four S in the series 2, and 260RS in both s1 and s2) have HICAS.
  • 3 weeks later...
hey i just read through this fourm and i saw that no1 said anything about wood grain cos mine is full of it, and also dose any1 have a 110v power point in the center console. cos i have read heaps about it and i havn't heard anything about.
i have pics aswell
i have pics aswell
I have woodgrain, but steering wheel is leather (25t x four) I also have the power outlet, I use it sometimes for the ipod with one of those powerpoint adapters you get from the supermarket
mine is series 2 rs-v prime edition do u have full leather? 6 stacker?
  • 4 weeks later...
Hi i´m new to this forum was locking for info about the stagea as i´m considering buying one.
I most apologize if my english is bad as it´s not my native language i´m from sweden.
I have found a stagea thats converted to manual and rb 26 in japan, so i need help to what to check, before buying.
Greetings from sweden
Hi and welcome!
The price conversion is $25kAUD, which is probably pretty reasonable all things considered.
Does that badge on the tailgate say '26X Four' ? (if it does, someone's having a bit of a joke and had the badge made up)
You should check to see if a modified car such as this can be registered - it would not be possible here in Australia to import and register this particular car.
It's still running the standard non-Autech brakes (see image #7), you'd probably want to consider changing them for something better if you plan on increasing the power output of the RB26. As per other posts in this thread - look for rust around the outside mirrors and around the front strut tops. Look to see how neat the conversion is (it looks ok to me.
You will have no true indication of the distance it's travelled due to it's non-standard condition.
Tanks for the help, the car is registred and finish to use, the importer say they have papers on that the conversion in japan is in standard to a factory car, so i´ll shall check for rust and if conversion is ok, clutch gearbox diffs elektronics etc.
Brakes i can get for good price: d2racingsports brake set.
  • 3 weeks later...
wow im way confused as to what i have now??
i got a feb 2001 rs four s,its manual awd with hicas and pearl white in colour and has 17 inch wheels,they look simuler to 34 gtr wheels,full body kit incld side skirts and rear wing,as far as i can tell i have all these options i think..when i closes the rear door(boot)it makes a weired noise like somthing electric like its locking or somthing,is this the auto door close thing mentioned??,can somone tell me more about my car,i was almost convinced for a minute i had a 260rs but am minus the 26dett,i must have an autech bonnet has the sticker under the bonnet says rb26dett( the sticker for idle speed and spark plug gap etc,any info on my car would be sweet
The rear door locking/whirring is exactly what you think it is.
Idle speed anywhere around 750-800rpm will do the trick. Plug gap of 1.1mm is fine assuming your coil packs are in good nick. IF you increase the boost and the spark breaks down you can lower the gap to 0.8mm or so.
RB25DET neo run 15deg advance btdc (not the 20deg of the RB26)
You should have R34 GT-t style seat.
Larger factory swaybars vs RS4.
That is a start anyway. All you need now is to get stuck into some mods.
  • 1 month later...
Hey :nyaanyaa: i am thinking of buying a stagea in the next couple of days - My choices are buy a series 2 with basic mods or buy a series 1 with all suspension upgraded , mods and stereo etc for around the same price.... I am concerned about standard suspension in both series 1 and 2 cars and it is making me only look at models with upgraded stuff as i have heard some pretty bad reports on suspension. I don't want to spend much more money after getting the car but did not know if a series 2 is ok as (stock / zorst cooler coilpacks) I know the trans, engine and some exterior features are different between the models but is it really going to matter once you start bolting stuff on to the engine?
Any advice would be fantastic and thanks in advance
Edited by uppon2
Hey :) i am thinking of buying a stagea in the next couple of days - My choices are buy a series 2 with basic mods or buy a series 1 with all suspension upgraded , mods and stereo etc for around the same price.... I am concerned about standard suspension in both series 1 and 2 cars and it is making me only look at models with upgraded stuff as i have heard some pretty bad reports on suspension. I don't want to spend much more money after getting the car but did not know if a series 2 is ok as (stock / zorst cooler coilpacks) I know the trans, engine and some exterior features are different between the models but is it really going to matter once you start bolting stuff on to the engine?
Hey mate, welcome to this section of the forums!
It comes down to a few factors when choosing a car:
  • If you want a factory manual, then your choices run to a series 1 260RS, or either the series 2 RS Four-S or 260RS models.
  • What do YOU prefer, looks and features wise?
  • Which of the cars you're considering buying is in better condition overall?
  • Have you checked out and compared insurance costs to see if they'd be the same?
  • What upgrades would you like to do that aren't on either car yet?
  • Were quality parts used for the upgrades, and was the work done to a decent enough standard?
  • Have you driven either of the cars you're considering buying, and how did they feel to you?
What bad reports have you heard about the suspension?
Don't forget, these are not exactly sports cars, so you can't expect it to handle "perfectly" considering the compromises that have to come with the extra weight and practicality of it being a wagon.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
