wrong part of the forum dude.... it clearly states "For Sale (Private Car Parts and Accessories)" which u had to click b4 u posted...u might want 2 try and post in the "Forced Induction Performance" under " Modifications & Maintenance " towards the top of the forum page.
... 4 got 2 add.. "nice car!!"
Edited by Player_Hater
you need to specify some more specs.
Is it stock motor with all the show attachments?
Is it a built motor?
How much power does it make, what is the response like?
One pic has a Trust turbo, the other has a HKS turbo... which one are you using?
IF you want answers your going to have to provide a LOT more information... attaching loads of pics really doesnt help anyone.
THE TRUST TURBO IS COMMING OFF AND THE HKS IS GOING ON ...THE ENGINE HAS HAD SOME WORK DONE TO IT ALSO.
THE HEAD HAS 2MM OVERSIZE FERRERA VALVES ,TOMMIE 270 DEG CAMS CUSTOM LIFTERS ,PORTED OUT ,FERRERA DOUBLE VALVE SPRINGS,BOTTOM END HAS CP PISTONS, JE OVERSIZE RINGS ,BORED OUT , HEAT TREATED CRANK SHAFT, RACE BEARINGS , THEIR HAS BEEN A HEAP OF OTHER STUFF DONE BUT I GOT 490 RWHP ON 1 BAR BOOST WE HAVENT TUNED IT PROPERLY YET WAITING FOR THE NEW TURBO TO GO ON AND I AM GETTING A BIGGER INTERCOOLER...
I WANT TO TRY AND GET 700 RWHP...AND A 10 SEC PASS..
i run a digital ignition msd with 6 v8 supa coil packs its putting out 400 volts not nice if you get a zap... motec m8 pro runs the car has about 8 thousand worth of upgrades i got it out of a v8 super car last yea just after they had to change their computers to m800.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
