I was gonna ask the same question, im looking at an ECU for my R32 and someone told me about e-manage for Skylines. Tuning it requires a laptop and rough knowledge of fuel-air ratios so leave that up to a dyno tuner. But they come relatively programmed to start with so you can plug it in and drive away with a pre-programmed setting. Fuel-air ratio will be a bit better, engine timing a little greater so its not a bad thing. But for it to be fully sick get it dyno tuned. I rekn your looking at a 10kw boost from it after a dyno tune.
https://www.sau.com.au/forums/topic/92089-e-manage-on-r33/#findComment-1660501
the emanage is a piggyback and an expensive one at that, if you are looking at spending that much you should either consider a remap or aftermarket stand alone.
have a read of emanage vs aftermarket stand alone powerfc
http://www.skylinesaustralia.com/forums/in...showtopic=92051
https://www.sau.com.au/forums/topic/92089-e-manage-on-r33/#findComment-1661134
I'm using an Emanage at the moment in my S1 R33, it's not tuned yet though. I haven't had any problems with it after installing it, haven't noticed any power gains either. The car just runs as if it isn't there, until you either get it tuned or try to do a rough tune yourself with the adjustment dials on the front.
"But my mum says I'm cool."
https://www.sau.com.au/forums/topic/92089-e-manage-on-r33/#findComment-1662574
