After reading SK's comment on Mercury CDI coils I'm curious to know if the PFC can be made to work with any kind of multiple strike CD ignition system . I don't know anything about the HKS Twin Power but could it work .
Also for SK , what mods if any are needed to fit the Mercury coils on an RB cylinder head .
Any means of more complete combustion interest me but like everything there's a financial limit .
Cheers A .
https://www.sau.com.au/forums/topic/92090-power-fc-and-cdi/
I'm pretty sure that it would work on any ECU unit. What's needed is the Ignition output wires from the ECU. With these outputs you can wire them up into the Igition inputs for the CDI unit. For the RB26, you need 3 igition outputs to wire in and there you go.
The actual wiring for the CDI unit is not complicated mostly just 12V constant, 12V igition, ground & the inputs from the ECU, where that be a PFC or Autronics, etc.
As said you need to replace the coils your using atm with something complatible with CDI setup.
The HKS unit is a Plug and Play unit (if you purchase the harness) but there are a few different CDI out there.
Personally I like the Autronics 500R CDI unit working with the MSD coils or the Mercury ones.
Looking to purchase this type of setup maybe soon but just need to confirm with my tuner if he has any thoughts.
Edited by WetGTR
https://www.sau.com.au/forums/topic/92090-power-fc-and-cdi/#findComment-1660595
