Ive got a Nismo GT Pro 2 way centre in my r32 GTst diff.
Im thinking about swapping to a s13 ratio to get some more use out of the gearing, BUT i wanna keep my 2 way diff.....
What part of the diff determines the actual ratios? Someone said it is the ring gear(?) inside the housing? Ive found sfa info on it (hard to find) - is it a simple job of :
a : swapping the centre and half shafts from my diff housing to a s13 housing with the s13 ring gear?
or
b : sell my 2 way :rolleyes: and buy a s13 lsd centre and have it shimmed up (dont wanna go this route)
So is it the centre, the housing, or the ring gear? inside the housing that determines the ratio in the car?
thanks :P
Edited by Bl4cK32
https://www.sau.com.au/forums/topic/92100-diff-ratios/
The ratio is determined by the number of teeth on the crown wheel and the pinion. The number of teeth on each should be stamped on the crown wheel somewhere.
The crown wheel should un-bolt from the centre. You need to swap both parts (the CW and the pinion).
https://www.sau.com.au/forums/topic/92100-diff-ratios/#findComment-1660422
Crown and pinion gears like above.. thankfully you can just swap the correct ratio of these from another suitable diff to get a new ratio, and keep your fancy 2way centre.
just pull them out of the s13 diff and get them swapped across.. shouldn't cost much.
https://www.sau.com.au/forums/topic/92100-diff-ratios/#findComment-1660429
So all he needs to change the ratio of the diff to the taller s13 ratio is to swap thw crown wheel and this is a sraight fit.
Would somthing like this Work for a r33.What is interchangable in the 33gts-t
And the pinion gear - they are a matched set.
Should work for any (R200) combo - I recently did this to fit Stagea ratios (4.083) in my R32 GTS4 (4.375).
https://www.sau.com.au/forums/topic/92100-diff-ratios/#findComment-1661995
Haven't actually got it back on the road yet. But the speedo will be out by the ratio of the 2 gearsets. The Stagea gearset is approx 7% less than the GTS4's. It used to do roughly 3000 rpm @ 100 kph, so I expect to be doing roughly 2800 rpm with the new gearset.
I certainly plan on getting the speedo re-calibrated to suit the new ratios so I don't forget that the speedo now reads less than actual, and get photographed a few too many times.
https://www.sau.com.au/forums/topic/92100-diff-ratios/#findComment-1662496
I was just about to post asking the question of speedo recalibration. Is this a difficult or expensive job?
I assume that if a PFC is fitted this will read wrongly for speed?
Cheers
Gav
https://www.sau.com.au/forums/topic/92100-diff-ratios/#findComment-1663056
Already asked that one myself. I think they quoted $275. Not sure how it's done - someone suggested they fit a new speedo drive gear in the gearbox.
$275 sounds a lot, but it's only 2 photographs!
https://www.sau.com.au/forums/topic/92100-diff-ratios/#findComment-1663561
It cost $418 for mine to be done, but they also repaired some wiring and tested the oil pressure gauge so I don't know what the speedo adjustment really cost. They used some sort of ratio conversion box to do the speedo adjustment. eg. speedo cable from gearbox goes into conversion box. Conversion box outputs adjusted speed to speedo.
It seemed like a strange way to do it but it works. I've tested it with a GPS and its fairly accurate.
$418 seems like a lot but luckily it was before i bought the car. :D
https://www.sau.com.au/forums/topic/92100-diff-ratios/#findComment-1663955
im guessing, but id say it takes the speed reading off the dash, as i havent got my speedo cable working atm (no speedo reading on the cluster) and the pfc hand controller shows no speed.
Cubes has his speedo working, and the speed reading works on the pfc.
I dont know if its the same as for the std ecu though...?
https://www.sau.com.au/forums/topic/92100-diff-ratios/#findComment-1667355
Just followed up on the fix. They insert a converter between the gearbox and the speedo cable. One of the firms I spoke to will fit it for you in a day, cost $275. The other test then supply the converter (you need fit it) for $175.
Pretty sure I could fit it myself in under 1.5 hrs (at approximate labour rates).
https://www.sau.com.au/forums/topic/92100-diff-ratios/#findComment-1669994
Would this be a mechanical type converter or an electronic type?
https://www.sau.com.au/forums/topic/92100-diff-ratios/#findComment-1670731
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
