mines a mid ninety model auto im changing to manual soon so ill be taking box out if you can tell me how to tell if its right for you ill check as soon as i get it out!
have you tried genuine?well let me know what to look for and ill look:)
yeah but i am not 100 sure if its the problem so don't want to pay big dollars.
Its a small black box with wires coming out of it(all covered in black) one bolt holding it in and it should come out and has a small metal point at the end of the part that goes inside the gearbox.
Its on the rear left side of the box (siting in the drivers seat)
cheers mate much appreciated if oyu can have a look when oyu do conversion think it may still be series 1 and wrong but worth a look
MATE ILL HAVE A LOOK WHEN I PULL OUT THE BOX,
IF IT WAS RIGHT I WOULDNT WANT MUCH FOR IT PROB JUST
POSTAGE COST OR SOMETHING AS LONG AITS RIGHT?WELL ILL LET U KNOW
IF YOURS HAS ANY NUMBERS ON IT LET ME KNOW
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
