Well after almost 3 years, I can finally say im the new owner of an 88' Silhouette.
Bought it for $6k
Mods: well just an exhaust, Rb25 with Rb30 bottom end, external wastegate and BOV with a T78 turbo and microtech, Has run 310rwhp on 9psi.
Guy will be tunning it to bout 200-250rwhp till i can get use to it and will bump it up gradually to bout 20psi with a cooler. Should make 400+rwhp but this wont be for a while.
Took it for a drive and its not that bad to handle, did give it some and wasnt too bad. exhaust will be getting fixed cause of a slight rattle and a newer clutch will be fitted aswell.
Should be out cruising in a few weeks once i get some more cash for roadie and rego. Pics attached below.
oh and thanks to mike and jaime for karting me back and forth over the weekend to see the car.
https://www.sau.com.au/forums/topic/92144-finally/
  • Replies 78
Posted Images
where's the 32 u promised that ud smoke me with last yr... :)
nice.
p.s - 25/30 and microtech is far from stock.... nor is 300+rwhp and 9psi
liar
lol wrong eug sorry mate try again I looked @ it with bennji & it is not a 25/30 sorry & not 300 rwhp
https://www.sau.com.au/forums/topic/92144-finally/#findComment-1661503
thanks guys, was planning on unveiling its potential at a dyno day.
Mods: Rb25 with Rb30 bottom end, external wastegate and BOV with a T78 turbo and microtech, Has run 310rwhp on 9psi.
https://www.sau.com.au/forums/topic/92144-finally/#findComment-1661566
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
