  • Replies 78
Posted Images
yeah bennji some thing I forgot to tell u with running in the motor try & not sit
on one speed for to long for around the 1st 500km just to help the rings bed in so to speak, yeah james the gates set to 7psi so no high boost for bennji :P
https://www.sau.com.au/forums/topic/92144-finally/page/2/#findComment-1661929
8's will be sweet, it will be wheelspin heaven. Good to hear you've finally got a car....sounds like a pretty stealth weapon..hopefully you may be able to keep away from the police for a while....just a question but it isnt rego'd? So you have to get a roadworthy with all that etc?? Im assuming its not engineered? GL with it all anyway...oh and I hope that your wastegate isnt vented back in...under the passenger door is teh way..not that I know what that is or what it sounds like or anything :)
when your down this way come around and take me for a drive!
Matt
https://www.sau.com.au/forums/topic/92144-finally/page/2/#findComment-1665634
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
