cammos green r32 has a rb30 like bens in it
you will need a foward facing plenum or else you will have trouble shuttin ya bonnet tho
yeah as james said unless u want to dick around with after market bonnet u need the forward facing plenum the RB30 sits up a lot more then the 20's do
https://www.sau.com.au/forums/topic/92144-finally/page/4/#findComment-1671907
  • Replies 78
Posted Images
yeah as jaimes said unless u want to dick around with after market bonnet u need the forward facing plenum the RB30 sits up a lot more then the 20's do
about 40mm higher IIRC
https://www.sau.com.au/forums/topic/92144-finally/page/4/#findComment-1675116
hahah awesome!!
absolute bargain too well done. At least you have a live axel rear end so you should be able to get some even traction/tyre wear. From the power figures its making the same as what mine was and trust me, your going to need bigger tyres
what gearbox is in it??
https://www.sau.com.au/forums/topic/92144-finally/page/4/#findComment-1676290
So is it fast? :(
I would just get widened steelies, and some hubcaps on them, and some nice semi slicks and just not drive it in the wet :D
If your cluch is stuffed too, go see Jim Berry, he'll fix it.
And, please always leave at least 1 lane gap between your car and mine if you ever see me, I dont wish to die when you decide to spin 4th up the motorway :) thanks!
Awsome awesome sleeper tho, try keep it quiet.
https://www.sau.com.au/forums/topic/92144-finally/page/4/#findComment-1676330
  • 1 month later...
That funny shroud isnt what they call a twin scroll compressor housing??
block is 38mm higher then std rb blocks. You slot out engine mount bolts holes and let it drop down to clear bonnet if u dont have a forward facing plenum eg greddy/gtr plenum. Or go drift spec and raise the bonnet at the rear.
https://www.sau.com.au/forums/topic/92144-finally/page/4/#findComment-1786635
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
