You hear an echo..........
Running rich because of the BOV.
I'd say your original one is a plump back version were this new one vent to atmo.
Your air flow meter already has sensed the air go in so it provides the fuel for that amount of air. When the air gets vented out and not back in....too much fuel and that's when you get the popping.
Even if you place the silcer back in and don't hear it, it is happening, running rich that is. Not a huge issue as it only happening at the time its venting out unless you have an air leak now from the BOV or the BOV is not sealing properly.
You'll have to check this out.
https://www.sau.com.au/forums/topic/92166-backfire/#findComment-1661640
I have a R34 GTT with a HKS SSQV on it & it does the same thing, it never use to before i put the bov on. Its nothing to worry about.  :P
Does this only occur on the first 10-20mins of driving though. Thats what happens to mine then it dissapears.
https://www.sau.com.au/forums/topic/92166-backfire/#findComment-1661886
do you have a hard and soft setting on the blow off valve?
if it is, let it idle and give it a blip, if it goes back to normal idle speed i wouldnt worry about it
if it goes below normal idle speed, ya keep turnin it hard till it stops .
it wouldnt hurt gettin someone to have a look at it too , just so you know for sure theres nuthin sus about it.
THanks
Barret
https://www.sau.com.au/forums/topic/92166-backfire/#findComment-1679396
THanks
Barret
the noise seems to have gone away
i have loosened the spring though..so it is on soft
https://www.sau.com.au/forums/topic/92166-backfire/#findComment-1679436
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
