Boost Controllers seem to be the topic of the month.
Well anyway, I just got my PFC tuned, and my tuner attempted to set my HKS EVC 3 up (it has never worked properly) and he couldn't get it going (boost keeps spiking or is constantly hunting). He has lent me a dirly bleed valve till I get a new controller (tossing up between PFC kit or Blitz SBC Spec R).
Before I went and spent my money, I was wondering if my piping had been setup properly.
I looked at Dad's R33 GTR setup to compare (he has the factory solenoid), I noticed that his only had 2 lines. And mine has 3 and another one with a bolt in it to block it. There is an jacket over the line with the bolt in it, and the line that the filter closest to cam.
Then there is a smaller line that goes to the throttle body, it's running of the same line as the round thing (fuel pressure regulator?).
And then there is a line that is the same size as the 2 OEM ones, and goes to dissapears to the same place as the 2 OEM ones.
All the pipes barring the bolted one were connected to the HKS unit, now only the from the throttle body is, and that gives a boost readout (it reads too high though)
now is that thr right way for the pipes to be set up, I thought that you would want all the lines to be the same size to get an accurate boost reading (the smaller pipe from the throttle body is giving a high reading)
So my question is, is the the right configeration for the HKS EVC III. Should I swap the small line, with the blocked line.
Any help would be appresiated.
Edited by sav man
https://www.sau.com.au/forums/topic/92172-boost-controller-help/
Maybe its just me but unshore of the pipes you are trying to define.
I beleive you are going about this the right way as if you get the wrong vacuum line, things like boost, fuel pressure,etc that require the correct vacuum pressure will be all over the place. I use a HKS EVC III and they are a terrific unit. Unless you are sure, don't throw it away.
Maybe if you outline and label what you are talking about, it will help to determine the problem.
Just 1 small vacuum line cost me $500 in a wrong tune, had to get it done again. Was not happy for something trivial.
Right, see how my english skillz are now.
This is what the setup was like before the blled valve.
and this is where the vacume hose comes from
I was thinking of turfing the 4mm vacume hose, and hooking the spare 6mm hose up (as it used to be on the OEM solenoid)
I was also thinking i could use the line that is hooked in between the turbo and cooler, and put it in's proper imput, and the line that's went to come from the throttle body, but i don't know how well it would read vacume presure.
I though pressure was relitave to the area it's filling (larger the area, longer to pressure up/lower pressure) so all 3 lines on the HKS unit should all be the same size shouldn't they?
I'II try to help but looks like a real mess in there. Firstly you should download the EVC manual and that shows how to do the vacuum lines.
Secondly, it won't make a difference if you change them to bigger or the same line cause the items connected just need to measure how much vacuum there is not actually using the vacuum to do a task.
First there are 3 points where there is true vacuum.
One: near your fuel pressure - small
Second: on the opposite side to this - small
Third: Under your AAC unit - where your inlet plenum is - large.
Be carful not to use anything from the inlet plenum as this will give false readings (happened to me and hard to pick cause there is some vacuum but it's wrong)
You can connect multiple items to these hoses so don't worry.
If this doesn't help you then we have to follow exactly where each line comes from and where it going. That way we clean up this mess.
If you know someone with the same engine - copy them, this would be easier.
I'll try to help where I can.
cheers
Adam
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
