just looking for some info on the falken RX 04V (i think thats the code..maybe RX 042V, RX 04V2??) they are supposedly a sort-of-semi slicker, looks like a street tyre with fat chunky tread blocks, not like a RT 215 or RE55s bridgy.
i can pick up set for a good price but i cant even find anything via google on these tyres! nothing on the falkentire web site either...
any help would be great!
https://www.sau.com.au/forums/topic/92198-falken-rx-semi-like-tyre/
OOh i found something, but its not really any good to me. At least i can confirm the model number "RX-04V"
FALKEN RX-04V Sタイヤ 245-45-17(2本)
How can this tire be so hard to find details on!? Dont suppose anyones used or using them???
These ones right?
They are good I have used them once, got them for $220ea in 245/45/17 from Tempe Tyres
Definately better than any street tyre, but not among the best semis. If you want great but not best performance at a brilliant price grab em :D
no thats not them! They dont have a semi slick look at all, they just look like a road tire with chunky tread blocks. I think ill just buy em and try em!
The words "chunky tread blocks" should ring alarm bells.
The RX series of Falken Azenis are rally tyres (which also matches your description). Whoever told you that they're "some sort of semi slick" either misheard someone else talking about them being a type of Falken competition tyre, or trying to offload them after buying a whole bunch thinking they were RS or RT series tyres.
Are you building an R33 offroad rally car? If not, tyres you steal from a taxi will probably do a better job of providing you with traction than these things on sealed roads.
Here's Falken's actual motorsport range.
As you can see, the RX-04 series are winter rally tyres, which means that not only will they not grip very well on the tarmac, but they'll also overheat within minutes of light use.
You can buy and try, but I get the feeling if you're making 265rwkW that you're going to conclude your rhyme with "die".
The falkentire.com web site is the American site, and its pretty much useless for competition tyres. They only list Falken's street tyres, with the RT215 / RT615 being the pinnacle.
Edited by scathing
These ones right?
i take it they arent 'road legal' tyres?
and are these the ones you mean, SLY33?
Azenis RS-VII
Azenis RS-VII
thats like what im talking about! im fairly sure the model number is different tho, but ill post em up when i get them. So go blow your snow tyres out your asses guys ;) hehe
LOL
PROBLEM SLOVED! now i feel better :D
As mitchy suggested the tyres i was asking about are in fact AZENIS RS-VII's.
The reason why i couldnt find any info on them is because these particular tyres are coded RX-04V, as i orginally posted. The reason for this is that these tyres are coded specifically for Australia and Canada, hence not bearing the RS-VII code as it would in Japan.
Definitly NOT snow tyres!!! so i wont be needing those snow chains sewid. :P:) lol
I thought it was iffy at first with the model number situation, but as you can see, they are identical to the RS-VII's.
see? like a street tyre but with chunky tread blocks! :D
by the way, the compound is very soft, even when compared to my medium compound RE55s, also the sidewall stiffness doesnt seem as stiff as the RE55s, so im expecting some decent straight line traction! I only plan to run them on the back, as on the street the RE's warm up slowly and cool down quickly. A friend whos running these on the street says they hook up crazy. Ill post up a review when i get them on.
Edited by SLY33
Yeah I've used these ones too, have you already got them? I think you will find these are actually a wet compound tyre and they don't take a hard time too well.
Ie Fatz and I wore them down to the canvas in 3 days of light competition.
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
