I have posted this in here as well cause i figure some of you may of already modified yours and can give me the heads up.
Ok so as most of you would know that the standard lights in the R32's are not that flash so i was thinking of getting some white night globes.
Now the high beam H3's are not a problem and got them in and a HUGE difference.
Now the low beam H3C's are a little harder as i can't find anyone that stocks them in Australia and if i buy them from JAPAN then it would be $180 to get a set delivered to me. Now i dont know about the rest of you but i thought this was a little steep for globes.
Now i had a couple of options.
1) install a set of driving lights. This is reasonable cheap option but did have its draw backs as well. Mainly being that cause of the intercooler piping it doesn't leave much room which means that the overall size of the DL would be under 600MM and not offer me much more light.
The other problem is the legal issue's and getting booked for DL's as most people do and dont really want the worries of something so stupid for a defect
2) Find another set of globes that will offer me more visiblity at night making it easier to see and still maintain the original set up.
This proved a little harder than expected as the only H3C's i could find were stock replacement globes and would not offer me any more visibilty.
I couldn't find anything over 2000K and couldn't see the sence in paying $50 for stock globes which wouldn't improve visibilty.
3) Obvisouly a HID conversion is the best but very expensive and not what i want to do as i think its a bit excessive for what im looking for.
SO after lots of thought and studying of the globes and the stock head light set up i came up with another option which i think should work and cost about $50 in total for new low beam Blue Vision 4000K globes.
Still not 100% sure if it will and i'll keep all posted.
If anyone has upgraded there globes if you could post up or PM with where you got them that would be appreciated.
Cheers B
https://www.sau.com.au/forums/topic/92214-r32-headlights-dull/
You can use H3 globes instead of H3C, you just have to modify the ground wire on it. This way you will be able to purchase Philips BlueVision globes to get that white/blueish output which is much easier to see at night.
As you probably already know, that H3C's are only pretty much only available as standard Narva items, or more expensive white japanese made globes. However I did see on Ebay that there was H3C's in a white/blue globe for around $89, however I think the H3 option is a much better one.
Nath
Nath
yeah i was thinking of modifying the H3's but it didn't work.
For some reason no matter what ground point i tried the H3's would not run in the low beam.
Yet run perfectly in the high beam (as inteded to)
I was told that you can solder onto the globe, but being stainless itseasier said than done.
I will have a play around some more and see what i come up with.
Cheers B
upgrade to whatever headlights i have on my 32! no clue what they are, maybe some sort of GTR ones, but they are awesomely bright and actually make use of the fog light button on the dash! (they've got seperate fogs built in.
well worth the upgrade IMO.
you can come check em out if you like sometime.
cheers
cheers
Might just do that Bart.
As i cant see sh!t with mine <_<
sounds like you got the same problem as my mates 32, his headlights are so dull on low beam that he drives around on high beam
http://www.prestigemotorsport.com.au/au/st...sp?StockID=1469
thats his car
YEAH i think there all pretty much the same Tim, and you cant see Sh!t at night.
I have adjusted mine but i to get around with high beam most of the time. :P
Tried Phillips Hi Intensity or Plus 50? Bout the best you can get without going to High intensity discharge. [expensive!]
Cheers,
Shaun
Well the main problem is i can't find anyone that stocks them at all.
The Phillips are a stock replacement and i dont gain any extra light with them so a waste of $50 if you ask me!!!
And i have not been able to find anywhere in Tassie (or anywhere else at the moment) that stock aftermarket or stock H3C so it makes it a little hard.
But i have fixed my high beam and just drive with them at the moment :)
But i have fixed my high beam and just drive with them at the moment :huh:
It is possible. Just did it to my GTS-4. Drill a hole in the base of some Narva H3 Artic Blue globes and solder (Stainless isn't fun but can be done) a spade terminal on the end and they run like a dream. PM me for more details or pics!
Cheers,
Shaun
Edited by MadR32GTS-4
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
