Yeah.... Very Pleased with my purchase..... I have had it about 8 months now.... Unfortunately though with the front bar being so low it is getting a little worse for wear from the bottoming out it recieves every so often.... I dont think it would still be up on the DC Import site though so I can't point you to a picture of it...
Very scmick car though...
Regan: Do you know or have any other way of finding out what it had in the way of mods before I purchased the car??? I know I got it with the full exhaust and air pod but it still seems to have an unusual amount of go behind it??? The only thing I have noticed is that it appears to have had some form of gauge mounted on the steering column????
Thanks
Brett
  • Replies 66
I do have one picture of it I copied from the website when I bought the car but that is on my PC at home ( am at work now :P )
To clear up any confusion my front bar is black not that grey in the other photo too :)
I will see if I can dig up the photo... I will post it tommorow if the file isnt too big. One thing to remember though is that the Rims have changed since the photo... I didnt like the 3 spoke rims that it came with...
Hi Brad,
Glad to hear your GTST is going strong, the front bars can be repaired as they are very thick at the bottom and can be repaired successfully(unlike the paper thin ones) I think the grunt with your vehicle is due to the dump pipe arrangment I think it is a quality unit Trust? I think yours was the first one I have seen and your right ,does make a big improvment to performance. It allways confounds me that guys spend big $ on A/M computers and AFC,ect and neglect the exhaust system remember air+fuel =power!!!!
Back to work now!!!
Regan
  • 3 weeks later...
Hey regan, Nearly actually bought my car off u as well but by the time my dad got around to putting a deposit down it was sold - which is fine as it was a n/a and i really wanted turbo and what u had in turbos was limited at the time. But i recently worked with a guy that used to work for you as a mechanic by the name of todd - good guy!! My kit for my car - the back wing came unstuck and so eventually did then front spoiler - but the main reason for that is because its been lowered quite a bit and drags on the slightest hill so its been my own fault but the back wing is a bit dissappointing as the boot buckled for no reason and one side came detached and the other side cracked a little (GTR kit) fixed now but i think with kits you have to expect a bit of maintenance now and then even with my parents hsv's parts of the kit have needed attention. Anyone buying a skyline in WA i would recommend regan...... although not sure if u do many skylines now days tho.
ive actually had a didgy GTR bar fitted to my r33, been a long time ago(4yrs) i didnt know too much about this sort of thing. Im am sure that the big metal bar was cut off int he process.
I also know of another r33 with the same thing happen to him.
To make things worse, the shop i got my kit from is a very well known shop(J.. S....), but the service was shocking and pathetic.
Im a bit worried now about my front, and ill need to rectufy it soon, it is a worry when the well known work shops are performing nasty works like my example.
Beware fellow Sky' freaks
whish u told me sooner. i left my car there at their shop for over two hole weeks. to make things worse... i paid up front. service suck asssssssss. i wouldnt go there again. the paint job isnt all that flash.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
