well you'll find theres an accessories wire that goes to the back of your head unit.. i cant rememebr the colour of it off the top of my head. but with a multimetre it should register ~12v when the key is set to accesories or on .. wth my boost guage i wired it up to my illumination wire, as i didnt need to see the light on my guag unless it was dark and i had my head lights on too
but yeah.. unless someone can correct me i would just say get a terminal block and tap into the illumination or accesories wire on your headunit... however this may require the fuse to be changed with added load
-Ruffels
cigarette lighter...
i used that as a remote wire in me landrover to wire up a amp/sub... only problem with it is when u got the keys out of the ignition and turn on the radio (only when im cleaning it ect) the sub dont come on... i was prepared to live with that so it was all good
hmm .. my deck isn't wired up so I can have the radio on with keys out .. but ciggie lighter is an easy spot to take 12v from .. cheers.
I'm probably going to go with this. I'm going to make a "harness", which will plug into the cigarette lighter harness to power my gauges. Benefit of this is it isn't permanent...
And, I don't smoke anyways.
    • And at over $2 per litre I'm starting to consider setting up a corn mash still and converting over to alcohol and running mine on it !  Up side of that is it all doesn't have to go into the car ! Win win !
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
