the original 260rs wheels are 17 x7 bbs .. front are +30 offset,rear +20 offset,you need spacers and longer wheels studs for rear to use 34or 33 gtr rims from my experience ..finding the right rims for my car has been a real pain ..so left them std ...too hard
The R33GTR wheels fit perfectly on the RSFour, standard studs and no spacers. I wonder what the difference is compared to the 260RS.
:P cheers :(
not sure but std 7jj 20/30wheels will fit on front to back but car handles funny...different..18x9 34gtr rims +30...hit shockies on inside rear
Now I am confused;
A 9" rim (229 mm) with 30 mm offset is 144 mm in and 85 mm out
A 7" rim (178 mm) with 30 mm offset is 119 mm in and 59 mm out
A 7" rim (178 mm) with 20 mm offset is 109 mm in and 69 mm out
So a 7" rim with 30 mm offset is 25 mm further away from the shock than a 9" rim with a 30 mm offset. A 7" rim with a 20 mm offset is even further away, 35 mm in fact.
It can't be the shock that they are hitting, unless the bottom spring seat is lower on the 260RS's than the S1 or S2 RSFours. The picture of Brad's R33GTR rear ended Stagea shows what happens when the spring seat is too low, it fouls the tyre.
The other alternative problem is too tall a profile tyre, but that would also have serious speedo error issues as well.
:P cheers :(
Here's an interesting link to some guff on wheels. tyres, and all things offset.
Even has a calculator to determine what should be running - if you know what is standard in the first place!
http://www.chris-longhurst.com/carbibles/tyre_bible.html
can anyone with an s2 rs four s (manual) (ie comes with 17" rims standard) check their placard on the drivers side door jamb to see the specs including offset and width of the original rims.
...Cheers
Now I am confused;
:) cheers :)
re: the std 7jj rim
if i put rear + 20 on front ..they stick out of guards to much
if i put front + 30 on rear ..they fit but not much clearance to shock/spring
9jj + 30 is perfect for front but hits rear shock without spacers.. on my car anyway
I've only got an S2 2wd and the drivers door placard looks exactly like the photo further back in this thread. The car came with a users manual from JPNZ covering WC34 models - 2 and 4wd. It's tyre chart looks like this
Tyre Rim Size PCD OFFSET
195 / 65R 15 91S
15 X 6JJ
205 / 60R 15 91H
15 X 6.5JJ 114.3mm x 5 holes 40 mm
205 / 55R 16 89V 16 X 7JJ
dont know if this is any help - it makes no mention of 17' rims
thanks anyway guys but i really need the info for the 17" rim, is there anybody on the forums with an s2 rs four s manual?
(other than "thedriver" as i already PM'ed him but he hasnt been online for about two weeks.)
Mighty ford falcon! Finally good for something!
the rims i am getting are 18" by 7.5, with 235 wide tyres. 114.3x5 stud (obviously enough).
youll find that any set of rims up to 18 inch designed to suit an AU or BA falcon will fit. same stud pattern offset, caliper clearance, you name it. i had the boys at superior tyres at aspley fit 4 sets of wheels, each for an AU/BA falcon to see how they look, and they all fit. both on the hoist and on the ground. dont foul on anything. you have my word!
Sorry, I've been on a desserted island for the last 2 weeks and have only just made it back to the mainland.
I don't have the original tyre placard on my car. I guess it was replaced during compliance. The placard on my door lists:
205/55 R16 tyres on a rim size of 6 1/2 JJ 16
225/50 R16 tyres on a rim size of 7 JJ 16
However my car is fitted with 17" Nissan OEM rims that I have also seen fitted to other S2 RS Four S model Stageas in Japan. I have a feeling there is more info in the compliance documentation so I'll check that when I get back home.
Yep. Wifes out in it at the moment, but according to the compliance papers -
Rim size and profile: 7.5 JJ 17
Rim Offset: +40mm
Wheel track front 1450mm
Wheel track rear 1515mm
Wheel Center to top of wheel arch -
Front Unladen 400mm, Full bump: 310mm
Rear: 380mm, 300mm
- and I have 225/50 tires on (obviously on all 4 wheels!). Works fine :-)
That's for a 2001 S2 four S. :-)
I can pull a wheel off and check what is says on the inside next weekend if you want.
Edit: Wife home, but the label on the side of the door doesn't say (just gives the tire size and preasure). So I'd have to pull a wheel off and see if it was actually the same as stated in the compliance papers..
Ian
Edited by ian
I was wondering about using the spare if you have larger wheels than normal and you get a puncture.
Would doing this have an adverse effect on the 4WD system?
Would I be better of carrying a puncture repair system (e.g. Slime) and a 12V compressor in place of the spare?
What sort of size difference can the system cope with?
lol, cheers but i wouldnt worry too much about it ian, you have pretty much given me all the info i needed (for compliance reasons)
muchly appreciated, oh and by the way your RS FOUR S is awesome, i love the colour!
Just wondering why those running 18" rims are using 235/40/18 tyres as opposed to 22/40/18 tyres that have a closer rolling radius to the standard 225/50/16 tyre, apart from the fact they are wider?
Wouldn't the 225/40 have a narrower sidewall than the 235/40 - this is purely visual difference
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
