I too have this question My S2 came with some nice Volk racing wheels and they say they have a +30 offset but they also have about a 30mm adapter which I believe is illegal if the offset is correct why is it that they need the spacer also the wheels have a totally different stud pattern to the car it seems like the spacers may be made for the wheels, could this make them Legal ?
Phill
The wheel sticker you have shown says the stud pattern is 5H 114.3 which is the same as the stagea, so they are they same stud pattern
At a guess is your car a manual?
18x8 +30 will fit fine if it is a "auto" as the rear track is wider by 50mm than a manual
If your car is a "manual" than it has the narrower track rear end, so the spacers will make the wheels sit out further so they fit (clear they rear shocks) and look better by filling the guards out
Any spacer is illegal
If you are worried about it, sell the rims and get a lower offset wheel.
Hi Thanks for that and yes it is a Manual, I tried to fit them without the spacers but the stud pattern was different ? they are closer together than the Cars hubs
Also who would buy them if they are Illegal ?
Phill
Phill
That is strange the wheel stud pattern will not fit without the spacers
Are the wheels multi stud pattern, ie do they have 10 holes?
Sell the spacers seperatly to the wheels
Many people mod their cars and not worry about it being legal
Not sure who would do that thou :D
Early Volk Jap wheels had small (approx 5/100) bolt pattern + big positive offset and then spacers/adaptors to suit different vehicle bolt pattern's.
Seen a staggered set of subaru wheels like this and personally replaced a set on a supra.
ok, new wheels are FINALLY on.. yet to get it wheel aligned so still some tweaking to do
s14 cradle fitted in the rear with cusco adjustables all round, cusco arms up front too
standard metal guards lipped but not flared
work vs-kf
18x9.5+2 R disk (95mm dish) 235/40/18 silverstone
18x9.5+1 O disk (120mm dish) 235/40/18 federal
why is the track on manuals narrower?
does this mean 'shorter' drive-shafts?
what other shafts fit?
thanks
work vs-kf
just wondering why you put the 14 cradle in?
was it a straight bolt in?
any other things you had to change to do this?
thanks
thanks
thanks
A s14 craddle is the same width as the stagea manual cradle.
The main difference is the S14,S15 and R33 GTS (non turbo) cradles do not have Hicas, so it is the best ones to use when reusing as much as possible of the stagea auto rear end.
Generally you change it to get the narrower rear track so it matches the front end and you can fit better wider and lower offset wheels.
Drive shaft length is shorter. Stagea have 3 different styles plus 2 different tail shafts. So use either skyline or s14/15 that suits your cars diff bolt pattern
The reason the manual has the narrower track is nissan was saving money and reused the rear end out of r33 GTR's. The manual also has stronger drive shafts etc, hence nissan used these in manual stagea's
Mike can fill in what he had to do to make this work.
nice thanks for that!
so stageas do not have hicas?
so manual stageas have the diff and driveshaft out of the 33 gtr, ie. big 6 bolt half/drive shafts?
doesnt the gtr diff have hicas also though?
"So use either skyline or s14/15 that suits your cars diff bolt pattern" : do you mean half shalf bolt pattern or tailshaft bolt pattern?
thanks!
darrin pretty much answered everything
i went s14 cradle myself because my car does not have hicas, and i didn't want to fit a manual stagea cradle that has it (means i can run aftermarket adjustabletoe rods, which i am)
the part you have put in quotation marks, he is talking about half shaft bolt pattern. the gtr rear end is a 6x1 bolt from memory, s14/s14 is 3x2 bolt and r33 is 5x1 bolt (which i am using to match my 2 way diff in r33 housing)
My auto stagea series 2 had 5x1.
The stagea manual one I have now is 6x1
Both had the same diameter drive shafts
There is 2 different tail shaft sizes as well. My car had a fairly heavy looking one and a I was also given a much lighter one, but thru it in the bin
ive read all 15 pages and nobody has tried or is running 17x9+35. my 18x9+20 bbs rims are a perfect fit. im just wondering if the extra 15mm further inwards would make the wheel scrub on anything?? shocks, inner guards etc.??
that's 5mm less than an r33/34 gtr wheel. should be fine
    • It could be in the tune but in both cases it couldn't be completely solved or eliminated by some of the best tuners in victoria so I'm DOUBTFUL that it's in the tune or ECU but stranger things have happened of course. I've pondered that theory too but is there any theories that thinner and smaller ports overall would cause a turbo to spike? I would've thought it would just restrict it in general if it was small enough to make a difference. I wouldn't expect it to make a different at what is essentially sub 300kw at 4000rpm anyway. I think the next step is going to have to be the 6psi spring to rule out the idea that the gate is cracking open far too wide initially. At least that is the cheapest (free) thing to check initially.
    • I'm thinking it is skinny NA Neo port sizing and cams. Somehow.
    • -5’s did it. 8474 did it. Not hot side related. ECU related? 🤨🤪
    • Above you mentioned you only need to sand primer if there's an issue with it but with fillers it says the surface needs to be sanded to X grit beforehand. Does that sorta contradict that point as the primer hasn't been sanded yet? At the same time if I sand the primer, there's a good chance I'll expose the bare metal and I'm just chasing my tail at that point. Or I'll just use a sand sponge instead of sandpaper, it seems to be far finer in terms of abrasiveness as opposed to sandpaper. From what I understand, filler is like primer and needs scratches from the sandpaper to help it adhere to the panel. I realised the way I'm doing things is actually a bit counter productive as there's a chance after I put filler I will need to put epoxy primer again as opposed to putting the filler first and potentially no primer if I don't go to bare metal. Will keep this in my mind for the rest of my repairs.
    • Not without making up a new screamer pipe from scatch I don't think based upon the angles of the current return. Backpressure shouldn't be an issue though as the straight gate isn't affected by backpressure in the same way that a poppet valve is, and on top of that the exhast system is 4" all the way through so there should be minimal pressure if any to begin with.
