ok guys, this is a killer for me. im trying to fins some rims that fit the rears of my RS4S, since the stock r34gtt rims wont fit without 20mm spacers, and the r32gtr rims have the same story.
one is 7.5 +38 for the gtt rims and the 32gtr are 8 with +30 offset.
i found some nice rims im trying to get which are 17x9, and im wondering what the best offset for the rears will be
i can get them from -25 to +15 in 5mm intervals.
is -25 too much?
when i ran the r34gtt rims with my 30mm spacer, i still had another 3cm to fill in the guards on the outside of the rim.
at the moment im just in need for some rear rims.
is -25 too much?
Don't they need to be the same all around to make sure all four wheels have the same rolling diameter? In answer to your question I think you'd be after about +15. Mine (pics above) are 18x9.5 +15
i have same rolling diameter all round, 17" gtt fronts and rears but want to replace the rears so i dont need to use the spacers.
im going to opt for deep dish steelies 17x9 i just need to know the best offset.
as 16x8 +30 doesnt fit and 17x7.5 +38 didnt fit.
i did try 17x8 with a +0 and that filled the guards very well
just thought that 8j is too thin for my liking plus they were only lend rims.
so yours is a rs4s?
ok quick question, quite urgent, i have a RS4 auto, sitting at 340mm, wondering wats the best size rims to go, widest offset possible. with a 18x9/9.5 rim. so +30 the best or will a +10/15 fit? need to fit both front and rears. thanks
nah, dont care for the front of yet, just trying to sort out the ass. im having heaps of trouble finding decent offset rims, so im getting custom steelies made :D
What's the cost on those?
if i have the centre piece its 150 per rim. but found a set of 17x9 +5 so i might buy them.
i hope my calculations were correct. i ran 17x9+38 on the rear, with 35mm spacers, so they technically were 17x9 +3?
they had a perfect offset
Hmmmm, might have to get new others for my watanabe wheels :-) and put my 17x8's on the front and make the 7's into 9's (stagea is going so the r31 will probably see a bit if love)
Looks awesome, what brand of rim are they? what size tyre and did you need coiovers to fit them at rear?, all he rims i have been looking at are 17,18 x9 +28
cheers
darren
they are work emotion CR KAI's, been lowered to 340mm, with camber. just misses rear guard by mm when bounced (without folding over lip), nd have about 3 cm still to go before hits strut. coilovers help. nd running a 245/45 tyre on it. thats when using the Auto wider rear cradle.
Edited by import_zone
been looking through this thread for ages and still not sure if the wheels I'm looking at will fit.
wheels I'm looking at are 18 x 9.5 + 20 and going onto a s2 rs4v (auto)
from what i can find the fronts should be alright with rolled guards
anyone know how the rear will be with the wider rear track of the auto?
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
