Stagea Wheel Dimensions?
thanks for that, got bc coilovers going in this week. not sure what sort of camber ill end up with.
the wheel also comes in a 35 offset but thinking that would sit in to close to the strut and i don't really want to run spacers.
I did a few things to it over the xmas break
Tein Coilovers
Whiteline Swaybars
Cusco castor rods
Adjustable front upper arms
S14 subframe (no hicas) to convert to eyelet rear struts
Nolathane subframe bushes
Nolathane arm bushes in all rear arms
Adjustable rear upper arms
To Do shortly
R34 GTT 4pot front brakes
R33 GTST twin pot rear brakes
R33 GTST master cylinder
will be a struggle to fit i think. not only with gaurds but also shocker. does ur have auto or manual rear cradle might help as well. but a 18x9+30 just fits autos, **x9+28 fits with gaurd roll. so would be a tough fit i reckon if its got auto cradle in rear. but manual might hit shocker.
Tein Coilovers
Whiteline Swaybars
Cusco castor rods
To Do shortly
I have an R33GTR master cylinder BM57 -
  • 3 weeks later...
rota grids are affordable and are becoming a popular choice nowadays.
Heck yeah. as long as above isn't sarcasm.
Affordable means they can live on a daily.
How much poke if any are people gettiing on 19x9.5 +15s on manual C34s.
I want as little as possible, as mentioned its a daily.
Also how much scrubbing, and guard work is needed.
By my dodgey maths, it seems like as long as i dont go too low should be sweet.
    • hello everyone, an RB26, or RB25 project in the medium long term. I don't know much about this engine or turbo engines in general, I'm here to understand and gain knowledge. I have specific objectives for a project
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
