for reference
17x9 +37 had about 3mm of clearance to stock struts
so i'd say you'd want a 15mm spacer on the rear (about 13mm more inset than the 17x9), maybe 20mm, but then you'll probably be poking out the guards
and as said before, you need the same tyres all round
so stretch 245's onto the 11's or run 265's on the 9's (latter is probably better)
Edited by pipster11
the different rotational speeds
ecu sees rears going faster/slower than the fronts and tries to help you out
Then its welcome to surge city!
Mine was doing when one of my rears was slightly more worn than the other
It's rolling diameter !!! Tyer wear would not be enough to trip it, currently I run staggered sets on all my stagea's but as long as you run close enough to the same rolling diameter you'll have no probs
Example 1 19x8.5 and 19x9 running 235 40 18s all round
Example 2 18x8 with 225 40 and 18x9 235 40
Example 3 18 x9.5 with 235 40 and 18x10 265 35
Plus I've had other sets on the car that have all worked out with no surging . Like I said just get close as with in rolling diameter and you will be right
To be honest i think its fine as long as the rears are bigger than the fronts
100% my atessa gauge was creeping up when on the highway (nearing 10 on the gauge)
I changed 1 tyre and its fine now
Also the car was surging at 100km/h
  • Like 1
I found this - had 2 tyres replaced on the front for RWC and got some serious surging issues - chucked them on the back and its aok
tyres dont need to be the same just the rolliang diameter does :)
Ok so using the pirfect wheel specs for an Rs4S
18X9.5 +12 all round
what tire profile do you recomend?
i will most probably roll the guard lips for comfort, i just want it to tuck in nicely, obviously beinf 4wd the front and rears need to be the same.
might get a mate to fit a 235 on on, see what the stretch is like, still unsure of brand so it will depend.
coilovers arrived otday so gonna drop it and see what sort of cavity im looking at
ok i seem to be getting idfferent information from different wheel calculator sites, can some one help me out with some dimensions.
CII Rs4-S c34
it currently has R34gtt wheels fitted which i beleive are
17X7+40
as they are from a RWD R34 they sit quite far in the guards.
just fitted my BC coilovers and when going over bbumps when the wheel cambers in the rim touches the coilover thread.
static it is a few MM off.
its the rears which are touching on bumps, the fronts are fine.
i am going to use maby an 8-10mm spacer to solve the issue but the new wheels are on they way and im confused as to weather they will foul aswell.
they will be
18X9.5 +12
one site sais i will loose inner clearance and another sais it will gain so im not sure.
Edited by GH05T
The wheels should be stamped with their size somewhere inside them, they usually are. I'm guessing they're +30, not +40 offset. An offset of +40 is usually for FWD cars.
Are you using an online tyre calculator? There are plenty around if you do a Google search.
well they are R34 GTT stock wheels which from searching on SAU seem ot be +40
i am using online tire calculators which is where im getting the conflicting information from.
does anyone know of one which they would trust?
Edited by GH05T
had the exact same problem, but both my rears where bold and my front where 95%, and started surging aroudn the 90km/h mark, and the gauge had about 10% i removed the plug under the dash that brought the 4wd light on and limpt home (130km's)
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
