RS4s wheels are 17 x 7.5 +30 I just replaced mine recently. Don't have them anymore as I sold them so I can't be much help on the measurement side of things.
what are you running now and what are your clearances?
If you have a look on page 8 there is some pics of my car there with rims on it. In terms of fitment my guards are standard e.g. no rolling. The front outside edge of the rim is pretty much flush with the guard. The rear is in ever so slightly, maybe 10mm. On the inside I reckon I have close to an inch of clearance from the inside of the wheel to the shock body. The overall height of my wheels is near enough identical to the 215/50/17 inch tyres I had on the car before.
I could have my car alot lower without any clearance issues, I used to have it alot lower on my 17's but i kept scraping the underneath when going into the driveway and over speed humps so I raised it about an inch. Heres a couple of pics
(FYI I run Greddy coilovers so not sure how this would compare to standard struts).
post-39581-1250229527_thumb.jpgpost-39581-1250229603_thumb.jpgpost-39581-1250229643_thumb.jpg
im looking at buying a rs4s and ive got a set of rims in mind that are 19x8 with +35 offset, do you think i'll have issues? or will they sit too far in, eg look crap
it's probably pretty clear by now that my wheel fitement standards are a little more agressive than the majority of you blokes and that by my standards they really will look sunken to all buggery
look at petes white rs4s a few posts back, the wheels you are looking at will sit 39mm in from them :S inner clearance will be about the same
hmmmm
i just looked them up and it appears they will extend out further than the standard rims by an ENTIRE 1mm !!!
but the rims im looking at dont seem to be available in a smaller offset :(
anyone else running on aftermarket wheels that only just extend out or are the same as the standard rims??? .....with pics???
at the moment im looking at either Konig - Hotswap Silver or Vault Crystal, both are 19 x 8 with +35 offset. also considering the vaults in 20 x 8.5 +35 but im not sure if they will foul the strut
i know its been a long three or so years, most certainly glad to be back
i put down a deposit on the new stagea today
Great to hear Andy.
Mikey is going to help me fit something to the yellow pig soon....when they are in stock so if you want to come over and share a beer and wave your hands around and point while I flounder around you are more than welcome.
  • 5 weeks later...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
