Well I've bitten the bullet and ordered my new wheels. Getting a set of Work Emotion XT-7s in 18x8.5" +25 offset. It turns out that +25 is only made for the USA market EVO 9s and 10s. It has not been released in Japan. I'm getting mine out of the US. Should be hear in a week or so (I hope). Can't wait. I'll post pics :cool:
Ah so jealous! I looked at these about a month ago...and said if only. haha Cant wait to see what they look like on your's. What colour did you order?
Hey there guys,
Just want a quick second opinion.
Running an S2 with Tein Superwagon coils.
Looking at buying some 18x9.5 + 12, or 19x9.5 + 12 (would be running stretched tyres)
I've had conflicting opinions on the matter; thought I'd post that up here for some quick clarification.
Thanks guys
- D
you've not asked a question, what did you want to know? lol
if you're asking whether they'll fit, then yes. have a look back through the thread for my posts as they are my wheel specs
on another note, keep an eye on this thread in the next week or so - i've got something a little more extreme in the works :blush:
Hey there guys,
Thanks guys
- D
Just a straight question. Why would you want to have "stretched tyres"? First of all is it not a waste of money to have wheels wider than necessary? If its just a question of looks you can make sure the wheels fill the guards by choosing appropriate offset (or spacers if necessary). And do you not care that "stretched "tyres degrade the ride and handling? Not getting at you in particular - I see a few of examples even here in Gods own country - its just that i don't know anybody with stretched tyres to ask the question of.
Damn. I am having nothing but wheel dilemmas. We decided to go with Work XT7s in 18x8.5". I found out that they come in +32 offset from Japan or there is the option of +25 offset out of the US. I worked out that +25 offset would fit better, so I tracked down a local guy with connections to the US and he ordered a set. Then it turns out his damn supplier sells the set he had on hold for me!!! So now I'm waiting on my money back. It sounds like +25 offset are very hard to get. So now I have the option of waiting a few months for a set to come up (and chucking some crap tyres on the Stag to keep her roadworthy) or I bite the bullet and get a set in +32 offset from Japan. What do you guys reckon? I guess the other option is to go to 18x9.5". They come in +12 or +20. I know MIKE and Darrin are running these. I'm a bit worried they will stick out too far in the front. Darrin has a 34 front, so may have a bit more clearance. MIKE did you have to do anything special to run 18x9.5" +12? Any problems with rubbing? What tyres? I have stock 260RS suspension. So no camber correction or anything. Mmmmm 9.5 all round would be tough. Am I dreaming?
Oh yeah, I measured that there is currently about 27mm between the outer guard and the standard 260RS rim (17x7 +30) in the front. So going to 18x8.5" +12 offset would extend out an extra 50mm which means it would sit out past the guard by 23mm. If I went to 18x8.5" + 20 offset (what is recommended for GTRs) it would hang out 15mm pass the outer guard. Not sure how you guys have managed to do it. Maybe I didn't measure it properly... Parked the car on flat ground, lined a spirit level up with the outer guard and made sure it was vertical and then measured the distance to rim.. 27mm
18x8.5 +12 extend 50mm. . . .I think you meant 18x9.5 +12
18x8.5 +12 will EXTEND by 37mm
I assume you are using something like this to work out offsets
http://www.1010tires.com/WheelOffsetCalculator.asp
18x8.5 +20 only extends out 29mm
My offer still stands to try my rims.
Yeah, sorry I meant 18x9.5. Yeah I used that same website. Got it bookmarked :down:
Thanks for the offer. That would really put the issue at rest. Don't think I'll have time to drive to your place this week. Rediculously busy working on the house
Yeah, sorry I meant 18x9.5. Yeah I used that same website. Got it bookmarked :thumbsup:
Sounds like my weekend. I have a complete kitchen to build from scratch over easter.
No wonder my car never gets finished.
I run 18x9.5 +15 on my RS4s - same rear end as 260RS
Front could tuck in a bit with more camber but not excessive and rear is fine (bit close to strut but plenty of guard clearence)
thats what i want to hear
i'm looking at some 18x9's at +15 for an rs4s
what tyre size you running?
OK I give up! Ive been searching the forum for about an hour now and still dont know!
Will I fit 20's on my car? S2 Stagea RWD with Nismo struts? Or will I have to buy 19's?
Really want 20's though!
the prev owner of my car had 20's on it with rubber band thick tyres, ride quality would have been terrible, 19's will ride better but the secret to making wheels look big on stageas is getting a low offset so they stand in the guards
245/40R18 all round
If you need tyres, let me know - federals and silverstone cheap cheap
still a way off getting them, current ones are still round and i think clutch upgrade will be next on the list :(
would look sexy as tho :thumbsup:
hey guys, thank you for your advise, i think i will try 245 at rear and 235 front..
if your stagea is a 4WD, first use a tire size calculator (like this one, LINK) and check that there isn't too much of a difference in rolling diameter between the 2 sizes of tire you want to use. if there is too much a difference between the fronts and the rears it will cause issues with the 4WD control, ATTESA. if you have a 2WD it shouldn't be an issue.
I'm looking at a set of 18" wheels (haven't bought the Stagea yet) and need to know the standard wheel dimensions.
It's a Series 2 if it makes any difference.
Anyone able to tell me what the Diameter, Width, Offset, PCD and standard tyre size are?
Cheers!
Edit... It appears to come standard with 215/50 R17 tyres
I too have this question My S2 came with some nice Volk racing wheels and they say they have a +30 offset but they also have about a 30mm adapter which I believe is illegal if the offset is correct why is it that they need the spacer also the wheels have a totally different stud pattern to the car it seems like the spacers may be made for the wheels, could this make them Legal ?
Phill
Edited by Phillhunt
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
