ok guys, this is a killer for me. im trying to fins some rims that fit the rears of my RS4S, since the stock r34gtt rims wont fit without 20mm spacers, and the r32gtr rims have the same story.
one is 7.5 +38 for the gtt rims and the 32gtr are 8 with +30 offset.
i found some nice rims im trying to get which are 17x9, and im wondering what the best offset for the rears will be
i can get them from -25 to +15 in 5mm intervals.
is -25 too much?
when i ran the r34gtt rims with my 30mm spacer, i still had another 3cm to fill in the guards on the outside of the rim.
at the moment im just in need for some rear rims.
is -25 too much?
Don't they need to be the same all around to make sure all four wheels have the same rolling diameter? In answer to your question I think you'd be after about +15. Mine (pics above) are 18x9.5 +15
i have same rolling diameter all round, 17" gtt fronts and rears but want to replace the rears so i dont need to use the spacers.
im going to opt for deep dish steelies 17x9 i just need to know the best offset.
as 16x8 +30 doesnt fit and 17x7.5 +38 didnt fit.
i did try 17x8 with a +0 and that filled the guards very well
just thought that 8j is too thin for my liking plus they were only lend rims.
so yours is a rs4s?
ok quick question, quite urgent, i have a RS4 auto, sitting at 340mm, wondering wats the best size rims to go, widest offset possible. with a 18x9/9.5 rim. so +30 the best or will a +10/15 fit? need to fit both front and rears. thanks
nah, dont care for the front of yet, just trying to sort out the ass. im having heaps of trouble finding decent offset rims, so im getting custom steelies made :D
What's the cost on those?
if i have the centre piece its 150 per rim. but found a set of 17x9 +5 so i might buy them.
i hope my calculations were correct. i ran 17x9+38 on the rear, with 35mm spacers, so they technically were 17x9 +3?
they had a perfect offset
Hmmmm, might have to get new others for my watanabe wheels :-) and put my 17x8's on the front and make the 7's into 9's (stagea is going so the r31 will probably see a bit if love)
Looks awesome, what brand of rim are they? what size tyre and did you need coiovers to fit them at rear?, all he rims i have been looking at are 17,18 x9 +28
cheers
darren
they are work emotion CR KAI's, been lowered to 340mm, with camber. just misses rear guard by mm when bounced (without folding over lip), nd have about 3 cm still to go before hits strut. coilovers help. nd running a 245/45 tyre on it. thats when using the Auto wider rear cradle.
Edited by import_zone
been looking through this thread for ages and still not sure if the wheels I'm looking at will fit.
wheels I'm looking at are 18 x 9.5 + 20 and going onto a s2 rs4v (auto)
from what i can find the fronts should be alright with rolled guards
anyone know how the rear will be with the wider rear track of the auto?
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
