after having a long read through this very informative discussion i decided i would seek the help of this group to help me decide a fitment as i want to get it right as i need to order wheels.
1999 S2 260RS wheel fittment.
size 20x8.5 or 9.0 ?
offset i need help with any sugesstions ? i can order the wheels in any offset i want but i want a fairly even flush look that wont scrub
tyres size 245/30/20
does anyone have a set similar to the above please comment also about how they look.
thanks
I run 19x9.5 +12 with 245/35/19
Go at least 9 inch wide, not 8.5
No rear guard rolling needed. It is tight with 5mm clearance to rear guard and 10mm to rear shocks with 245's
Make sure rims are "A" type at front to clear brembo's.
Type A or Disk A refers to the caliper clearance.
I do not think it is a industry standard, but most Jap brand wheels quote it
Rule of thumb is A suit big calipers like Brembo, B type will suit GTST calipers and Type C will normally only work on the rear with small calipers
It also depends on the shape of the spoke.
I run 19x9.5 + 12 in a type B front and rear and have r34 GTT calipers. My rims only have 1-2mm clearance to calipers. I would not fit brembo's
If they were type A there would be approx 10mm clearance to the calipers. The Type A will also effect the amount of dish/outer rim you see.
Type B will have more dish/outer rim
The main thing to remember is, rim width and offset are not the only thing to consider. Make sure to consider the caliper clearance as well esp on a 260RS
What wheels are you considering buying?
Also find yourself on online wheel calculator
That way you can put in either your stock wheel sizes or mine and compare to the ones you want to buy
The calculator will tell you the increase or decrease of both the inner and outer dimension changes
try this one
http://www.1010tires.com/WheelOffsetCalculator.asp
http://www.wheeldude.com/catalog/product_info.php?products_id=5774&osCsid=a1e4576cc4ab64f7fa9ff1a4839aa460
Can anyone shed some information and tell me if something like this will fit on a RS4-V auto.
Many thanks
Joe
Sorry, yeah she is an auto.....
I shall start looking at my options then. Around $4k to spend including rubber.
If you have 4 k to spend you should look at getting your rims via Jesse Streeter. I got him to order some Work xsa for me, they custom make them to order at the sizes you want. Mine in 18" cost under $2200 delivered and they are a 2 piece wheel. Then just over 1k for a set of kumho ku31's. O ly problem is waiting near 12 weeks for the wheels but worth it IMO.
no problems running staggered as long as the tyres are EXACTLY the same
offsets sound a tad ghey
i think for rs4s use r33 gtr specs
something like 18x9+12 or 18x9.5+15
www.willtheyfit.com, measure up your current clearances (plumb bob and ruler to see how much inside the guards they are now) chuck in your current wheel specs and play around with offsets till you get something you like
Fitted these up last night.
After initial dry fitup concerns they fit sweet, thanks darrinspencer and everyone else for convincing me 19*9.5 +12 will fit a manual.
Its still quite high, but being my daily I dont want to increase camber just for the low yet and kill my tyre life.
My phone camera (and my location choice) is sucking at taking photos of black rims with any detail...
looks perfect to me
I'll go 18x9.5 +12 too i reckon....when i get my new wheels.....in the distant future
what kit is that?
what kit is that?
Its all as I got it so I'm not 100%.
I assume the car was originally a Dayz edition as the rear lip and spolier is as per dayz.
The front bar and skirts are series 2 RS260 as far as I know.
My wife calls it the underbite.
I run 19x9.5+12 all round with a 25mm spacers on rear and 245/35/19 rubber heaps of clearance with camber and rolled guards, I could go up to a 255 with out issues but a 265 would propably scrub the suspension.
Or
18x9+30 all round with 25mm spacers with and 265/35/18 these only just clear the suspension on the rear but have heaps of clearance on the front.
PS the ride with 19s is shit house, I can only imagine 20s would be crap.
19inch Volk GTC's in silver.
pcd 114.3
Front 19x8.5 + 30 face 2
Rears 19x9.5 + 24 face 2
do you guys think these will fit 260RS ? providing same size tyres are fitted
just a few pix of my wheel fitment on the Stagea 260RS
Tyres are 235x40x18
rear wheels 18x10 +13
front wheels 18x9.5 +24
im considering selling these wheels also so if you know anyone let me know.
Edited by PRIMO
  • 1 month later...
hi guys/girls I've just bought a rs4s manual (just waiting for compliance :O) and looking at a set of wheels.. they are 18 x 9" +20..im not sure how these would fit and what size tyre! any help would be appreciated.
Edited by jwelshy19
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
