If they are 7+40 vs 9.5+12 you will have 4mm less inner clearence and extend out wards by 60mm
Shit.
This means on the rears on 18x9.5 +12 I would need to run maby a 15m spacer. That's not cool.
Surely sonething is not right here.
Has anyone else ran these specs on an rs4s
From this thread they seemed to be ideal specs...
This is what I'm getting with stock R34gtt wheels
You can see where it touches. Mainly going up a driveway on an angle when there is flex.
I'm assuming the specs for the R34gtt wheels are right. I got them from the skyline wheel specks thread, I will check the wheel itself tomorow when it's light.
Anyone else running 18x9.5 +12 on their rs4s who can check their strut clearence?
Edited by GH05T
I thought gtt 34 where 7.5 et 40 which means you will gain 3mm clearance on the inside and a further 53 mm on out so yeah you will have to run spacers inner clearences to strut must be vastly diff on manual hmmm
gaining clearance is good....
gonna use some slipons for the time being...hopefully 8mm will be enough to clear.
it only touches when angeling spoon drains and driveways.
will check the offset when i get the wheels off at work today to confirm their specs
also im sure the lowering has added a little bit of camber which will be sucked out when i fit the new wheels
the kms i do anything other than 0-0 camber is madness
Edited by GH05T
Yeah lowering will add camber, and then with the slip on spacer and new wheels you should have over 12 mm inner clearence ;) will be fine a bit of extra poke out the back won't hurt anyway
ok stamped on the R34 wheels i can confirm is
17X7 JJ +40
so im going to loose a further 4mm clearance from the inside on the new wheels.
hmmm so 18X9.5+12 DO NOT FIT RS4-S stageas
when the new wheels arrive i will need to test fit them without tires and see what is going to need to be done to clear them to my liking and how much outer extension im going to get.
the wheels will naturally add 60mm (from the R34 wheels not stock stag wheels) and im assuming im going to need maby a 15mm hubcentric spacer to properly clear them.
maby less once the wheels lift the car a bit and the camber is taken out.
so spacers, roll the guards 235/40 tires, 0 camber and we should be ok, gonna look fat either way.
a tiny bit worried about the extra strain on the bearings but meh.
amazed that the issue was with the rears on the 4WD seing as i understand they have a narrower subframe (more like the R33gtr?? )
and the fronts are happy as larry.
Edited by GH05T
yeah thats what i have been reading too.
well the truth will come out when they arrive i guessshould be early next week.
im hoping i have missed somethig, mis calculated something misread something, and they fit without further modification but i dont see how.
i cannot imagine the coilovers would make that much of a difference, they may be thicker but their is only so much difference they could make.
Well I'm perplexed jet r31 is running 9.5 + 20 on his auto with Bc coilovers "the rim to coilover should be the same between autos and manuals just the out side diffrent " he has 5to 6mm clearence at I think neg 2 camber so if we look at that you at 9.5+12 should have 8mm more clearence on the inside so a total of 13mm clear and stick out 8mm more but ya got heaps of rm that way :) !!!! Then if I look at me I'm attempting to run a 10+5 so
Just took a pic of mine for you (sorry it's sideways, uploading from phone and it rotated it). As you can see there's quite a bit of clearance with the stock shocks, I'd say a good 15mm. Obviously BC's are thicker though. I'm not sure how much but you can work that out. Mine is as stated earlier s2 rs4s running 18x9.5 +12 with 245 40's.
well wtf is goin on here. i cant work it out.
is their anything that could be different on my model?
1998 Series 2 RS4-S manual 4wd
everything looks stock appart from the BCs, unless my wheels have been tampered with...nah im just pulling at straws now.
i will be VERY interested when the wheels arrive for test fit.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
