  • 3 weeks later...
  • 2 months later...
  • 1 month later...
Does anyone have a definitive answer on what fits a RS4S? I've read every page of this thread and I'm even more confused than when I started.
I hear we have a bit more room at the back and I'm looking for something quite large either 18 (perhaps 19) x9.5 or x10.5 all around but I'm a little unsure of offsets front to back (back particularly)
  • 1 month later...
This thread helped me so i will post pics.
98 S2 awd manual with 18x9.5 +15 235/40 front and rear. Ride height is 360mm front 350mm rear. Guards are untouched. I did have to play with the front camber as the rims were poking about 10mm. I got it down to 3mm. Rear is flush.
Hi all, looking at new shoes for my stag.
Can I get 18x8.5 +43 on her? She's RWD, not lowered (yet), but looking to S-Tune suspension her
That's a horrible offset, you'd be better off looking at +30 with that width.
They're going to look horribly sunken on the car.
Thanks Erop. I have been wanting to find out if anyone is using greater than 9.5" width on their M35 Stagea.
I'm thinking of getting either 18 x 10 (+25) or 18 x 10 (+15); most likely will be the (+25) given your rear guards required modification so (+15) will certainly be a struggle
Z33Fairlady, 10" width is a bit too much on the ftont. 9.5 +25...22 is the good choice for WB car. 10 inch wheel is as close to knuckle, as it is fitting fender outside. 10 with +25 or more with tyre wider than 245 will probably not fit because of the knuckle.so the +25 is the only inset for 10" rim and 245+ tyre.
PN-MAD, either Black or white rims-i have to wash car twice a week to keep it red, not grey.
  • Like 1
  • 2 months later...
  • 3 months later...
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
