Woo, actually +6 8.5 will not be good. I just remembered I'm running 8.5 fronts. That puts you 13mm further outboard than mine. Will be poking quite a bit by then.
In 8.5s +18 will be a great fit.
I just had a quick look on the will they fit page and did a measurements of my rear wheels with the 8.5" wheels. the +6 would sit as far out as my 9, where as the +18 would sit as far on the inside as mine, which scrap slightly so depending on your camber and how low the +6 may be the way to go on the manual for the rear. a
s for fronts the +18 are perfect (sit out about the same as my wheels but i am wanting mine to sit further out), but the +6 would make it about flush with the gaurd. but again depends on how low. and this is comparing to my RS4s and my dimentions on my wheels for you.
If you require pictures on my GTR wheels on for how they sit i can try and get them for you. but the will they fit page is a good site to check.
  • 4 months later...
Just thought I'd throw up today's work. I don't know why I waited 2 years to chuck some dish in, soo much happier with the look.
To begin with, my stag is an AWD RS4 with an auto rear cradle (however it has had a manual conversion, still running auto rear).
So my car came with AVS Model 5 18x8+38 (terrible, so I ran 25mm spacers all round)
I've gone with some rota filth and got Rota MXR 18x9.5+20 which in my opinion fit perfectly! Not too aggressive but definitely sits flush! Running slightly stretched 235/40's. Haven't noticed any scrubbing except maybe slight on the fronts with full lock however my front guards aren't rolled and the plastic is still in the guard - the rears are rolled though.
Edited by sekay1994
  • 4 weeks later...
I picked up an auto S1 that has some gashed stocky wheels, with tyres that are down to the belts. I'm budgeting for new wheels and tyres so that I can pick the specs, but I found a pretty solid deal on some rota drift teks with tyres. While these arem't the wheels I really wanted, they will pass a roadworthy, and keep some coin in my pocket for suspension parts. Wheels are 17x9.5 with a zero offset squared. tyres 225/45
Haha they won't pass. They will stick like 30mm out of the rear guard.
Good luck with those tyres - they are way too small.
Mine is Rs4s AWD manual. It sits fine on level ground but as soon as things start to move around they touch slightly on the rear coilovers (bc brand). tried 5mm spacers but it's not quite enough.
  • 3 months later...
Hello all, I wasn't able to find any photos of NM35 Stagea's with 16in wheels. Does anyone photos of their NM35 Stagea's with 16in wheels they are willing to post? I did see one post in this thread saying that V35 Skyline 16in wheels fit but there was no photo. What I'm looking at doing is getting some 16in wheels and tires for sure during the winter months. I'm in Canada and my Stagea should be landing on our shores in early November. I've been searching on Canadian wheel and tire supply sites but using 2003 Infiniti G35 Sedan as my filter for my 2001 NM35 Stagea.
On 8.9.2016 at 8:07 AM, marlowe said:
That would be great to see! Yeah I'm not certain if the NM35's have different brakes/suspensions but that offset doesn't seem to far off from the wheels I am looking at, a set of 16in x 7in with 40mm offset.
I have lowering springs in these pictures and axis model ;)
brakes and suspension are same m35 and nm35 I think :D
  • Like 2
  • 2 months later...
Hi all. Just got my 2006 PNM35 about a month ago. Could not be happier!! Just wondering if anyone knows the Genuine Nissan part number for the 17" x 8" +40 alloys that came with my car? Don't have a spare at the moment. Will eventually be looking at upgrading to 18s but will need to save for a bit.
Update: I believe they may be K40300M D33 05.
Edited by mprodo01
  • 2 years later...
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
