  • Replies 241
Posted Images
opens up a shit load of combos
i had many of these in my head the other day, and now i forgot them all
lol
R33 GTS isnt bad though, get it on a GTS-T and the cops might leave u alone lol
Edited by dezz
R32GTR, R33GTR, R34GTR were all available at 10:00 this morning.  All sold by 13:30.
:D
Would i be right in assuming that you've got them on reserve?
I can't put numbers in between letters in the query module? ;)
LoL, just in case you can't tell that is a R32,R33 or R34 GTR.
Awesome changes though, opens up too many combos.
They cost 500 bux though....
Edited by IOWNU
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
    • Absolutely. Look very closely at the photo (of yours) that I took my second snip of. See how the sill is thicker material right behind the pinchweld, where the two notches are? That is the factory reinforced area for lifting. That pad is supposed to carry the weight. The factory jack (go look at it, and how it interfaces with the car at the pinchweld) shows you exactly how the load is carried from the car to the jack to the ground.
    • if need be I guess I will, yeah. Just to be clear, it's okay to use the sill area around the jacking points for loading, meaning the actual pinch weld or jacking point just sits in the slot without taking on any weight?
