G'day, i was just wondering about crane cams hi-6 CDI ignition. I have an rb25/30 with an autronic, gt3540 (1.06) and i dont want to use the standard coils because of the problems they have. I am aiming for 350-400rwkw. What i am wondering is how the crane cams ignition is setup because it only has one coil when there were 6 originally? Anyone used this?
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/
You really need to get a multi channel to suit coil on plug ignition as your ecu is outputting the ignition triggers rather than a single coil with distributor type ignition.
Autrtonic have a multi channel CDI that can be used with external coils as well as MSD and Motec and the HKS twin power units.
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/#findComment-1663571
I have the Autronics SMC runnning in my car atm.
I am just in the process of purchasing a CDI unit after some good advice.
I'm going for the Autronic 500R CDI unit which are a top of the line product but the HKS item is not a bad item as well.
You can use your standard coils but they were not design for CDI setup and can overheat very quickly.
Many people purchase the Mercury Outboard Coils, MSD, M&W, Bosch coils as they are cheap and complatible with CDI setup.
If you have an Autronics ECU, I recommend going with the Autronics 500R CDI unit.
I don't know about this Crane product but I know alot of people have big problems when trying to setup a CDI setup so going the proven way works for me.
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/#findComment-1663740
Thanks for the info. Have you got any idea on the costs of these coils? particularly the mercury ones and of the 500r CDI itself?
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/#findComment-1663920
Got a price on the Autronics 500R CDI $888.80 which has GST included plus $15.00 for delivery.
The Mercury Units are $35.00 each but priced from the US
Got prices for the Autronics CDI from a few different placed but the price above was the best - placing the order tomorrow.
Edited by WetGTR
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/#findComment-1664177
bastard dammit, wish i shopped around, too busying relying on useless bloody workshops in perth (not naming names). B)
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/#findComment-1664218
Hi mate-I'm running a Crane Hi-6 and PS-92 coil on my 1FZ-FE with GT42. I'm also using an Autronic SMC. I've had absolutely no dramas with the system, and am running 390rwkw at the moment.
The problem I can see is the fact you are running multi coil. The unit I have is only suitable for an electronic dizzy configuration. I suspect you will be limited to a multicoil set-up.
Cheers
Sean
Adelaide
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/#findComment-1664654
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
