G'day, i was just wondering about crane cams hi-6 CDI ignition. I have an rb25/30 with an autronic, gt3540 (1.06) and i dont want to use the standard coils because of the problems they have. I am aiming for 350-400rwkw. What i am wondering is how the crane cams ignition is setup because it only has one coil when there were 6 originally? Anyone used this?
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/
You really need to get a multi channel to suit coil on plug ignition as your ecu is outputting the ignition triggers rather than a single coil with distributor type ignition.
Autrtonic have a multi channel CDI that can be used with external coils as well as MSD and Motec and the HKS twin power units.
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/#findComment-1663571
I have the Autronics SMC runnning in my car atm.
I am just in the process of purchasing a CDI unit after some good advice.
I'm going for the Autronic 500R CDI unit which are a top of the line product but the HKS item is not a bad item as well.
You can use your standard coils but they were not design for CDI setup and can overheat very quickly.
Many people purchase the Mercury Outboard Coils, MSD, M&W, Bosch coils as they are cheap and complatible with CDI setup.
If you have an Autronics ECU, I recommend going with the Autronics 500R CDI unit.
I don't know about this Crane product but I know alot of people have big problems when trying to setup a CDI setup so going the proven way works for me.
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/#findComment-1663740
Thanks for the info. Have you got any idea on the costs of these coils? particularly the mercury ones and of the 500r CDI itself?
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/#findComment-1663920
Got a price on the Autronics 500R CDI $888.80 which has GST included plus $15.00 for delivery.
The Mercury Units are $35.00 each but priced from the US
Got prices for the Autronics CDI from a few different placed but the price above was the best - placing the order tomorrow.
Edited by WetGTR
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/#findComment-1664177
bastard dammit, wish i shopped around, too busying relying on useless bloody workshops in perth (not naming names). B)
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/#findComment-1664218
Hi mate-I'm running a Crane Hi-6 and PS-92 coil on my 1FZ-FE with GT42. I'm also using an Autronic SMC. I've had absolutely no dramas with the system, and am running 390rwkw at the moment.
The problem I can see is the fact you are running multi coil. The unit I have is only suitable for an electronic dizzy configuration. I suspect you will be limited to a multicoil set-up.
Cheers
Sean
Adelaide
https://www.sau.com.au/forums/topic/92264-crane-cams-cdi/#findComment-1664654
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
