Bad Fuel Economy
mass_iv
 Share
  • Replies 40
I was hoping there won't be any charge actually, should be, well hope it to be part of their after sales service, hope that this type of thing still exists.
I know my tuner in Melbourne always gives me aftersales service & I always go back to him and recommend others.
Hope all tuners out there adhere to the same principles
Edited by WetGTR
I hope they look after him as well.
My car has gone back after initial ecu install at least ten times ( one occasion they used 120 litres of fuel and 15 sets of plugs) with niggling dramas and I have never received an invoice. Top guys. But to be fair they were not the cheapest workshop out there but its paid off with the phenomenal after sales support.
If your initial tune was dirt cheap I dare say they mapped for outright power/safety and not much else. Going back asking for economy might incur a bill. As the saying goes you get what you pay for. Good luck.
I'd be very suss about that fuel economy level. Take a look at what I have. Ive used your template as we have similar mods.
List of Upgrades:
1) T04e 460hp Turbo
2) Wolf3Dv4
3) Walbro fuel pump
4) Stock Injectors
5) Fuel Pressure Regulator Malpassi
6) No AFM (Wolf Map Sensor)
7) 240rwkw
If I drain the tank to pretty much empty I'll get 400km a tank. However, this is quite conservative driving.
i understand all the thoughts going round, but i will be taking the car back to the tuner... as for getting what you pay for, i paid $700 for the tune which is not that cheap.... hopefully he will come up with something and maybe ill get same if not more power with better fuel economy.
Go and speak to your tuner - he tuned the car, so he should be the best person to diagnose what's causing your bad fuel economy (presuming he's a decent tuner) and therefore hopefully rectify the problem as a result.
It's not un-common for tuners to have to perform a bit of a 'touch up' after an initial tune. They can't always get it 100% right first time after a dyno tune as obviously normal street driving can dish up a number of different driving conditions as opposed to the constant conditions on a dyno.
You have to also remember that your tuner isn't a mind reader. You need to speak to him so he can understand exactly what you're after. If you told him to tune for maximum power, then he probably predominantly concentrated on your top end power. You do have standard internals (I think), so your tuner was probably being safe by running the car a little rich in the top end. Presumably, he didn't pay as much attention to your light load AFR's (which he probably should have done regardless of whether you told him to or not), so they're probably a little rich as well. If that's the case, he should be able to pull some fuel out there which should improve your economy as that's where the majority of your daily driving probably occurs.
Good luck. Let us know how you go.
yeh will do guys, i havent had a chance to speak to him yet, but i will be having a chat, i think he has run it a little rich to be safe, but i dunno if he meant it to be as rich, it has a bad flat spot at about 2000rpm, which i thought at start was just the huge GT30R, but now its become obvious it just a fuel prob....
ill keep u guys up to date
Well its a start! :(
Alot of tuners always think that way -
If ever in doubt just run it rich :D
It can be very over done at times.
Has to be a balance - good tuners are getting that balance correct.
Query: Did you reset your ECU after the addition of the new aftermarket parts?
If not, do so, it might help somewhat. From what I understand, you should always reset the ECU after adding new parts. And you wont 'lose your tune' that you just paid for, as such.
Hope that helps?
Brendan
I dunno what's with my car then, but I get better fuel economy when I thrash it for the first 1/3 of a tank or so...just seems to burn more efficiently or something. Again, my R is fairly standard (310ps @ 1.0 bar), but if I drive it like a nanna everywhere, i'm lucky to 430km's to the tank. When I give it stick everywhere, I get 470....Go figure.
Maybe there's something odd about the way my car is setup *shrugs* I have a mines ecu, pretty sure there's an aftermarket fuel pump in there but dunno what as it came over from Japan like that.
Hope your car gets fixed up soon though :O
something else to consider for bad economy
ive been getting approx 350 ks to a tank
when i got my new fuel pump fitted, foudn out that my fuel lines were perishing and that there was a fuel leak!
if u got an old car, its worth checking out
ive replaced a heap of piping now due its age;
hmmmm its gooood!! :)
Nice to hear that he didn't charge.
I think its a good idea to always try discussing your problem if your not happy with something. At least it gives them a chance to discuss it.
What the worst that can happen....they do nothing, your no worse off.
If your still not happy, go back again. Same situation as above.
Hope all it well now and keep us up-dated.
thanks guys, seems ok now, i think he just fine tuned it a little more...
as for those leaking lines, i wudnt mind knowing where abouts i should look, as i have already replaced the lines from the fuel filter to the rail and just before the filter.
i would say from the pump as he was installing a new pump for me
i could always smell heavy petrol reversing up my driveway, but thought it was due to our lines running so rich
never noticed any leaks
could never smell petrol when the car was left over nite in the garage
Edited by Spooks_Skyline
 Share
    • Hi all,   I have been a member here for years and am back to owning an R35.  It's my car and thought members of the community might enjoy sharing my journey.  I am definitely here to join the conversation.  If sharing this content isn't appropriate or it belongs somewhere else, I am happy to have it deleted or moved...
    • Data looks rock solid? I'm assuming you jabbed the throttle twice OR once? the TPS voltage moves up and down twice, however you've mentioned you did it once.
    • Having not watched the videos, I'm unsure, but this may be better suited to the importing thread?
    • Update on this situation: (Forgot to put in my previous post that I bought another brand new pressure gauge and fuel shows the same 50psi) I've deleted all the aftermarket immobilizers and turbo timer shyt and placed all factory wiring back to normal. The problem is still the same and nothing changed, but atleast it's a bit more tidier under the steering wheel. I've also siphoned out all the old fuel and then poured new batch of BP98 fuel (about 15L) into the tank. Nothing changed. Still the same idle. I also changed out the MAP vac line with a new one and, still the same.  So 2 days ago, I thought fk it. I'll just change out the fuel rail and injectors with another set that I know worked well in my brother's R34 a while back. That other fuel rail has the exact same Xspurt 640cc as what I have right now. So I changed it out to that other fuel rail and injectors (new O-rings) and injector harness. Put everything back together, started the engine, 464906286_1624569924763105_5179888796065901094_n.mp4   and yeah... still the same 50psi and idle problem. 🫠 I can also hear each of injector's solenoids running when I put a screw driver to it and have the other end to my ear. I might get a noid light just to confirm pulsasion but yeah, very strange that both fuel rails and injectors put out 50psi.  31-10-2024.csv I've attached it here. I started recording, then started the engine and let it idle with no throttle, then at the end I applied a little throttle and then stopped recording.    So, now idk. I'm going to see if swapping out the brand new R35 coils to my old splits fires will change anything. 🤷‍♂️
    • Hey mate, nice work on the car. Just a quick note, people generally don't like it when you use the forums to dump and run to advertise your YouTube content. If you're gonna stick around and join in the conversation then great, but if not this might not be the best place for you.
