  • Replies 40
I was hoping there won't be any charge actually, should be, well hope it to be part of their after sales service, hope that this type of thing still exists.
I know my tuner in Melbourne always gives me aftersales service & I always go back to him and recommend others.
Hope all tuners out there adhere to the same principles
Edited by WetGTR
I hope they look after him as well.
My car has gone back after initial ecu install at least ten times ( one occasion they used 120 litres of fuel and 15 sets of plugs) with niggling dramas and I have never received an invoice. Top guys. But to be fair they were not the cheapest workshop out there but its paid off with the phenomenal after sales support.
If your initial tune was dirt cheap I dare say they mapped for outright power/safety and not much else. Going back asking for economy might incur a bill. As the saying goes you get what you pay for. Good luck.
I'd be very suss about that fuel economy level. Take a look at what I have. Ive used your template as we have similar mods.
List of Upgrades:
1) T04e 460hp Turbo
2) Wolf3Dv4
3) Walbro fuel pump
4) Stock Injectors
5) Fuel Pressure Regulator Malpassi
6) No AFM (Wolf Map Sensor)
7) 240rwkw
If I drain the tank to pretty much empty I'll get 400km a tank. However, this is quite conservative driving.
i understand all the thoughts going round, but i will be taking the car back to the tuner... as for getting what you pay for, i paid $700 for the tune which is not that cheap.... hopefully he will come up with something and maybe ill get same if not more power with better fuel economy.
Go and speak to your tuner - he tuned the car, so he should be the best person to diagnose what's causing your bad fuel economy (presuming he's a decent tuner) and therefore hopefully rectify the problem as a result.
It's not un-common for tuners to have to perform a bit of a 'touch up' after an initial tune. They can't always get it 100% right first time after a dyno tune as obviously normal street driving can dish up a number of different driving conditions as opposed to the constant conditions on a dyno.
You have to also remember that your tuner isn't a mind reader. You need to speak to him so he can understand exactly what you're after. If you told him to tune for maximum power, then he probably predominantly concentrated on your top end power. You do have standard internals (I think), so your tuner was probably being safe by running the car a little rich in the top end. Presumably, he didn't pay as much attention to your light load AFR's (which he probably should have done regardless of whether you told him to or not), so they're probably a little rich as well. If that's the case, he should be able to pull some fuel out there which should improve your economy as that's where the majority of your daily driving probably occurs.
Good luck. Let us know how you go.
yeh will do guys, i havent had a chance to speak to him yet, but i will be having a chat, i think he has run it a little rich to be safe, but i dunno if he meant it to be as rich, it has a bad flat spot at about 2000rpm, which i thought at start was just the huge GT30R, but now its become obvious it just a fuel prob....
ill keep u guys up to date
Query: Did you reset your ECU after the addition of the new aftermarket parts?
If not, do so, it might help somewhat. From what I understand, you should always reset the ECU after adding new parts. And you wont 'lose your tune' that you just paid for, as such.
Hope that helps?
Brendan
I dunno what's with my car then, but I get better fuel economy when I thrash it for the first 1/3 of a tank or so...just seems to burn more efficiently or something. Again, my R is fairly standard (310ps @ 1.0 bar), but if I drive it like a nanna everywhere, i'm lucky to 430km's to the tank. When I give it stick everywhere, I get 470....Go figure.
Maybe there's something odd about the way my car is setup *shrugs* I have a mines ecu, pretty sure there's an aftermarket fuel pump in there but dunno what as it came over from Japan like that.
Hope your car gets fixed up soon though :O
something else to consider for bad economy
ive been getting approx 350 ks to a tank
when i got my new fuel pump fitted, foudn out that my fuel lines were perishing and that there was a fuel leak!
if u got an old car, its worth checking out
ive replaced a heap of piping now due its age;
hmmmm its gooood!! :)
Nice to hear that he didn't charge.
I think its a good idea to always try discussing your problem if your not happy with something. At least it gives them a chance to discuss it.
What the worst that can happen....they do nothing, your no worse off.
If your still not happy, go back again. Same situation as above.
Hope all it well now and keep us up-dated.
thanks guys, seems ok now, i think he just fine tuned it a little more...
as for those leaking lines, i wudnt mind knowing where abouts i should look, as i have already replaced the lines from the fuel filter to the rail and just before the filter.
i would say from the pump as he was installing a new pump for me
i could always smell heavy petrol reversing up my driveway, but thought it was due to our lines running so rich
never noticed any leaks
could never smell petrol when the car was left over nite in the garage
Edited by Spooks_Skyline
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
