It seems that I have fixed my lag problems with my 2530 fitted on my 32 by tighten my adjustable Act almost all the way (it looks like hks turbos need a lot more pressure holding them closed to offer the nice lag free boost 2530 are supposed to have)
But now my cars pinging on 1.2 bar (I know it's to high for stock ecu and inj but Ive gotta try) I want to lower the boost to 1.1 and increase my fuel pressure a little as my boss says I cant be WEAK an run lower boost than 1.1
last time my last time my car was dynoed it made 170 rwkw while the A/F ratio's were 10.1 ish (very rich?) so they the dyno operators uped the base timing to +20 they also told me that my car was already running less than stock base pressure 28psi and it was still running rich now I want to get it closer to the factory pressure which I was told was 38 psi
my boss has now lowered the timing back to a non WEAK +15 to try and stop the car pinging (1.6 bar will do that)
I just want to know which way to turn the adjustable FPR to richen up the mixture?
https://www.sau.com.au/forums/topic/92309-adjustable-fuel-pressure-reg/
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
