Just thought I'd let you guys know that my Boss has organised with the track owner for 12 Cars to be able Drift at PT Gawler every Monday night from 6pm-9pm (When daylight savings starts October 30th) $30 per Car and Spectators are free.
Contact me or me boss to book your spot
So far both the 30th and the 7th are all booked up mostly by NS guys
www.kansaiautomotive.com
452 Port Road,
West Hindmarsh, S.A
ph 8346 7077
https://www.sau.com.au/forums/topic/92312-pt-gawler-drift-practice-nights/
  • Replies 41
Directions for the peoples:
1. Travel down Pt Wakefield Rd, about 4km past Adelaide International raceway, then turn left at the Pt Gawler turnoff. Watch your speed as its easy to miss.
2. Travel down the sealed Rd about another 3km and turn right at this sign onto an unsealed Rd.
3. Travel about 200m's down the unsealed Rd and you will arrive at the Office.
Apparently "this sign" is just general signage and you shouldn't be able to miss it.
I'll be heading there after work and will probably be around for the 6pm kick off, if not then a little later, any other SAU-ers dead set going?
Nah i just went to check it out, i left straight from work so there i was standing in a dirt bowl in a shirt and slacks, to say i was the odd one out is an understatement. :angry:
Very much a "backyard operation" but i guess the price is low, the course looks pretty goo but you have to be careful about where you run off as the tyres can and did cause a bit of carnage to bodykits.
Kinda funny really, cause it wasn't me, but a blue ceffy was the first car out there, 2/3 of a lap down smashed his rear bar but didn't realise and kept going. Then his missus took it out, understeered it on the big sweeper, smashed off the front bar and got beached on some tyres. Had to get pulled out.
Oh and i should revise those directions, the distances are way off, i almost gave up, i thought I'd gone past it.
1. The turn-off is almost 10km past AIR, not 3km, you just need to look out for the "4WD blah blah hire course" sign (summin like that).
2. It's at least another 5km down the seeled road, and there's no sign, you just keep going until there's no sealed road left then turn on to the right-hand dirt road.
3. Those with low cars and hard susp, take it real easy on the road to the office, HEAVILY rutted and pot-holed.
Hey bud i went out to help out ryan (rap183) an his gf Bek, was a good night for practise. Cant wait to finish my 4 door an get back out there again.... Remember thrashin Pt Gawler in my S15 :)
Hey Oosh so that was you in the blue shirt out in the middle of the dust bowl hahaha Good work for Terry for hookin up the track agian.
Craig.
Yeah mate that would have been me, i left there at about 6:45, i should have given you my mobile no. so you could call me. Sorry.
Well maybe next time I'll see you up there, I wont be going next week as I'm in Melb with work, but maybe the week after.
I went out last night and helped johnnie out directing cars and giving people a push it was a little wet
I didnt end up having a go in my car this time as there seemed to be alot more than 15 cars out there already.
we still have a few spots for this Monday and hopefully it will be dry give me a call on the number below for bookings
  • 2 months later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
