ok, i have r32 gtst type m rb20 and i have a greddy type s bov in place of the stock one, it has the plumback running back to in behind the afm to the turbo, i took that off and let it vent to atmosphere and blocked off the plumback line should this be ok ? i know its illegal to vent to atmosphere but f*k i love the sound so much i cant help it, i know if i dont block off the plumback the car will stall + its letting unfiltered air through to the turbo,
i think i just need the whole process explained like the air that would normally be plumbed back if i had it connected comes in after the afm and as such isnt measured so i dont see why it would make any diff to block it off.
somebody please explain this to me :)
thanks ;)
https://www.sau.com.au/forums/topic/92324-bovplumback-question-~/
Hey Deanzzz, i know for a fact in the R33's and safe to say in the R32's too that the ECU uses the plum back pressure to regulate a/f ratio... now when the BOV vents the pressure into the atmosphere the ECU goes nuts causing an imbalance in air/fuel ratio hence stalling... the safest and best way is to use an adjustable plum back BOV such as the GFB Stealth.. these can be adjusted to how much pressure is atmospherically vented and how much is plummed back.. unless you change the ECU and update the AFM to a map sensor, ur greddy BOV will continue to give you the same problem! personally i think the standard BOV is the best upto 12psi - 14psi.. if you want sound.. a stock BOV + POD filter + FMIC will make enough noise to turn heads!!! Just a thought.... but if u really want that loud Ptssshhhh... get a GFB Stealth...
Regards,
Sarkis
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
