I wanted to buy a set of Adjustable cam gears (intake/exhaust) but heard someone saying that something needs to be altered, changed i dont know to fit the intake gear.... can any one expand on this? sorry my question is so vague, it was a long time ago that i heard this.
I drive a Series II R33 (if that makes any diff. to fitting)
Cheers
https://www.sau.com.au/forums/topic/92327-adjustable-cam-gears/
I would also like to know... What is involved and what cam gears are recommened??
I wanna finish off my exhaust this year!!!
What price range am i looking at??
A friend might be able to help me out since he did it, but i would just like to know whats involved and get the knowledge up atleast..
thanks..
Ok well im that friend hey sidd, lol... Ummm if you have a rb25det, you only need the exhaust cam gear and not the inlet, as people say the inlet didnt make a difference at all on the dyno..
The exhaust side is set @ -4deg which yields on average 10-15rwkw gain in the midrange... Definately noticeable when you put some stick into your car!!
In comparison on dyno figures to cars with the same set up - the exhust cam gear, mine still topped approx 10rwkw gain.
Its about a 2hr job with the right tools to pull off the old cam gear and replace with the adjustable one... It comes down to the tightness of the timing belt, as the cam gear cover has to come off, and you have to ease out the old cam gear.
Make sure you mark the lining up of your CAS before you take off the CAS and cam gear cover, so you know where to move it after the cam gear is on.
Take extra precaution on where the belt sits on the inlet gear, as you dont want it to move over a few teeth and wiggle the exhaust cam gear in after setting it @ -4deg...
Put it all back together, and I think you might have to move the CAS anti clockwise about 2mm to counter for the -4deg adjustment... Its either right or left?? But a proper timing gun would also help.
With the inlet gear it is an oil pressure activated VCT unit and can't be just replaced unless a new front end is welded on, so the whole cam must come out for machining. You also lose the VCT. Bass Junky has developed some VCT adjuster plates and has been looking for people to trial them. They work the same as with the exhaust ones then but with VCT.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
